Home > In Car Electronics (L322) > Radio problems (no sound and not turning on)
DTaylor
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Chawton White
3 days ago my stereos sound went off. Radio still beeped as normal and changed channel but no sound.
Since then the touch screen no longer comes on at all. Just shows landrover boot logo. And the button flashes orange.
If i unplug the cd changer and leave the car. Come back and plug it in it will come on to the radio part but still no sound.
So i have read previous posts. I have looked on the left side of the boot but see no water and havnt a clue where the fuse is for it. If anyone cluld help me find the fuse i can try unplugging it and see if that works.
Also had the aa out and tested my battery and said its good.
If not could it be the amp?
No sounds killing me, Any help is appreciated
Post #219970 31st Oct 2013 2:03pm
NKSC
United Kingdom 2005 Range Rover Vogue SE Supercharged Zambezi Silver
I had a similar problem with mine not booting up and just staying on the LR screen. It turned out to be a faulty bluetooth module - water damage to the plug.
This may help
http://www.fullfatrr.com/forum/topic19430.html
Post #220043 31st Oct 2013 7:06pm
DTaylor
I shall try this straight away. How do i go about bypassing it? They said to use a straw?
Post #220049 31st Oct 2013 7:28pm
NKSC
You have to take the two fibre optic cables out of the connector and line them up so they are pointing directly at each other. If you put one in each end of a short piece of a straw or some tubing it will do this. This bypasses the BT module and the system should then boot up. You may need to pull the fuse for the head unit to reset it but I cant remember which one it is.
Post #220052 31st Oct 2013 7:35pm
DTaylor
Well.... Bluetooth connecting fine with my phone but still no sound.
So guessing its not the btooth as it wouldnt work at all if bust would it?
Post #220062 31st Oct 2013 8:00pm
Mustard
Its been raining a lot recently and these things do like to soak up some of the rain through the rear end. I would double check for water ingress on both sides of the rear quarters and in the wheel well. If you dont find any traces of water temporarily wrap bin bags over the electrics on both sides and get the watering can or hose on the backend focusing on the D pillars, upper tailgate roof bolts & the roof ariel. Give it a minute or so and open the tailgate & start carefully looking for drips or puddles on the bags and feel the wadding around the electrics, dont be too surprised if you find water Censored in all over very expensive electronic boxes of joy ............... Land Rover thinks thats ok Rolling with laughter
Oh and when you do find water coming in, be sure to leave the bin bags on your gear until you've sealed up the leaks Thumbs Up
Post #220098 1st Nov 2013 12:47am
NKSC
Did you get this sorted??
Post #220671 4th Nov 2013 1:53pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
I find it funny that a car that can wade up to the windscreen suffers from a bit of precipitation Rolling with laughter Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #220705 4th Nov 2013 4:47pm
DTaylor
Still not sorted. Weeks of no radio. Unplug the changer an the radio comes on beeps when you press channels but still no sound. If you click into music settings it won't change options like move sound left to right. No sound option works. So I'm guessing it's either amp or speakers
Post #224946 24th Nov 2013 4:01pm
