Home > Maintenance & Mods (L322) > EPB Failure and Flashing brake lights :(
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Hi,
Can anyone help or point me at a resource? My EPB warning light is on, got the AMBER and Flashing RED. IID shows up general electrical failure and can't reset the fault. Checked the fuse, no difference. Where is the connector under the vehicle? I guess I need to check it's ok - the urgency for this is the fact that my rear brake lights are flashing like a police car while the engine is running and I will have to drive home in the dark!!!!! Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #219939 31st Oct 2013 12:12pm
have you tried putting the epb on and off a couple of times? ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #219941 31st Oct 2013 12:27pm
DMRR
Yes - it doesn't engage (no motor noise, no clonks, no whirrs, nothing). Lights came on while driving, not when parked or anything. Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #219943 31st Oct 2013 12:28pm
the only thing i can find re the epb is ref to the to the emergency release cable and as yours does not engage then its most probably no help...i suppose you've done the obligatory battery disconnection.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #219949 31st Oct 2013 12:42pm
DMRR
Disabled my DRL's and the EPB worked - then about 30 minutes later failed.
At key on - engine off - my battery reads 11.5v - is this too low? Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #219986 31st Oct 2013 2:19pm
slightly, try a drop test on the battery to see if you have any dead cells.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #219993 31st Oct 2013 2:59pm
DMRR
It's the original battery from 2006 - so I'm going to take the plunge and order a new one..... Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #219994 31st Oct 2013 3:00pm
you cant go wrong in a newer battery Thumbs Up
another thought, i wonder if your LCM is failing or not getting enough power.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #219995 31st Oct 2013 3:03pm
DMRR
No faults logged on the LCM - only the Parking Brake ECU and the TMC (always there). Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #219998 31st Oct 2013 3:10pm
ebajema
Wauw, 2006 that is very good for a FFRR battery !!! Time to change. Not sure about the TMC though, any faultcodes there ? MY 2010 5.0 SC Galway green and sand interior!!
Post #220017 31st Oct 2013 4:17pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
I pretty much always have the TMC antenna fault - but it works fine.
Post #220021 31st Oct 2013 5:04pm
DMRR
TMC isn't the problem and has always registered an antenna fault even though it works Smile Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #220026 31st Oct 2013 5:47pm
Katash
Mine too - although it sometimes required re-tuning
Post #220031 31st Oct 2013 6:27pm
DMRR
Well I am baffled. Had the battery tested, all fine and no need to replace. While there also re-ran fault clearing routine on IID - all cleared. Now I don't get a blank status message on first start (i.e. it doesn't remember which trip option to show, such as TIME, RANGE etc) and it seems very happy. No errors logged for EPB any more and battery seems to be like new Rolling with laughter Got to love Land Rovers! Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #220156 1st Nov 2013 2:30pm
