Home > Technical (L322) > Indicators not canceling??
stuboy00
Scotland 2006 Range Rover Vogue SE Td6 Java Black
Hi guys just back from a run in the rover and found a problem when the indicators are initiated they don't cancel when the wheel is straightened back? Any ideas? F**K IT you only live once
Post #220361 2nd Nov 2013 5:57pm
Dolphinboy
sometimes if you push them up or down too hard they pop out from behind the flimsy plastic covering inside the steering column cover. Just insert a small screwdriver or knife and pop them back behind the plastic cover. no need to undo or take off the column cover. Thumbs Up
Post #220373 2nd Nov 2013 6:34pm
stuboy00
Any body got any pics or diagrams for this gave it a try but no luck F**K IT you only live once
Post #220554 3rd Nov 2013 9:26pm
stuboy00
Can anybody help with this cause I've tried dolphinboys advise but I don't know what to look for I've had the cowling off but I'm at a loss now as to what to try and push back in???? Please someone help as this is really inconvenient now
Cheers stu F**K IT you only live once
Post #231741 28th Dec 2013 4:03pm
i dont know what the 'bits' to push in are but if you turn the steering wheel lock to lock and use the indicator ,you should see how it all works [or not] ... - .- -.
Post #231744 28th Dec 2013 4:54pm
stuboy00
Hi Stan yep tried switching the indicator turning the wheel to see if anything moved or was untoward but Question Question Shocked F**K IT you only live once
Post #231745 28th Dec 2013 5:02pm
