Home > Technical (L322) > TDV8 fuel filter removal
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
I've searched and learned that replacement of this is a 5 minute job but not sure and don't want to damage anything.
should the big black nut just turn by hand (mine doesn't) & is it a right hand thread? is there a special tool or way to grip it or just brute force?
Post #221052 6th Nov 2013 12:26am
wealy
Brute force!
It is a right hand thread, but more of a bayonet type twist. There's a knack to it but its really straightforward
Post #221055 6th Nov 2013 1:11am
wealy
When the new one is in place make sure the arrows line up
Post #221056 6th Nov 2013 1:11am
dexion7
so when you say 'bayonet type twist' do you mean that it is pushed in and twisted like 1970's indicator bulbs?
it doesn't want to move!
Post #221087 6th Nov 2013 10:30am
wealy
Give it some brute force - it will move! Twisted Evil
Post #221099 6th Nov 2013 11:18am
dexion7
i cant get sufficient grip to turn it. needs a giant pair of mole grips or something similar
Post #221100 6th Nov 2013 11:20am
wealy
I wouldn't use mole grips. Put one of those oil filter strap tools round it and try and tease it off, once it gets going it slips off very easily.
Where are you dexion?
Post #221103 6th Nov 2013 11:39am
dexion7
newcastle - it sounds like its so simple that once I've figured it out I'll be changing the filter every week just cos i can!
will try the oil filter strap tomorrow
Post #221219 6th Nov 2013 6:53pm
wealy
Yes you will!!
Newcastle staffs or north east ??
Post #221320 6th Nov 2013 11:18pm
dexion7
proper Newcastle!
Post #221321 6th Nov 2013 11:19pm
wealy
Why are you so eager to change it? They last about 25,000 miles?
Have you had some bad diesel or a problem?
Why not wait until your next service?
Post #221323 6th Nov 2013 11:20pm
wealy
The Geordie one then!
Post #221324 6th Nov 2013 11:21pm
dexion7
the car is 2010 SE 50K miles - one owner with full dealer history. Since i bought it Ive fitted new disks etc all around and I need to fully service it too else I wont love it!.
Post #221327 6th Nov 2013 11:23pm
dexion7
yes the Geordie one!
Post #221329 6th Nov 2013 11:24pm
wealy
Someone on here uses the phrase "if it ain't broke then don't try to fix it" !!
I'm guessing your fuel filter has been changed at the last service...
I'm also guessing your car runs nice and smooth - much similar to mine I guess!
As its a 2010 it may even still be in warranty at 50 k
I would leave it for another 10,000 miles and worry about it then!
If you are ever in my part of the world (over you next 10k) pop in and I will do it for you!
Post #221332 6th Nov 2013 11:30pm
