Home > Technical (L322) > 3 beeps possibly cured ?
steves025uk
United Kingdom 2007 Range Rover Vogue SE TDV8 Santorini Black
"Does the PDC light come on above the PDC switch when the beeps occur?"
No, tried pressing the switch before, during and after the beeps, no joy.
The quest contiinues.
Post #192875 9th Jun 2013 11:10am
MrP
England 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
What sort of beep is it? One that drives me nuts is the max speed warning that one of my kids keeps setting grrrrrr "On first name terms with my local Dealer......now."
'61 Plate 5.0SC Autobiography - in Black ——— Gone
'53 plate 4.4V8 Vogue Bonatti Grey inside and out. ----- Gone
Post #192876 9th Jun 2013 11:18am
steves025uk
It is the same tone as the front parking sensors, but three beeps, slight pause, three beeps etc. mostly carries on until I restart, sometimes goes away by itself.
Post #192880 9th Jun 2013 11:39am
as a last resort i would disconnect the battery for a while, dunno why but its something to do on a lazy sunday afternoon... ... - .- -.
Post #192890 9th Jun 2013 12:30pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Try disconecting the PDC unit .... see if that works.
Post #192905 9th Jun 2013 3:08pm
steves025uk
I believe the PDC unit is in the boot behind the fuse box on the right hand side ?
I saw this on You Tube referring to Parking Sensor issues.
http://www.youtube.com/watch?v=89engAgn-XA
Post #192906 9th Jun 2013 3:34pm
Katash
Yea its behind the fuse box but you should be able to disconnect the cables without taking the fuse box out - I did whilst diagnosing a PDC fault.
Post #192914 9th Jun 2013 3:57pm
steves025uk
I finally took the FF into Guy Salmon at Thames Ditton to see if they could cure the mystery beeping.
They said "probably chafed wiring from the front parking sensors" "we do them a lot". Bumper off, move the wiring. £99 for an hour.
They put the machine on it and it didn't show any faults and of course it was in beep free mode !!
They reckon the parking sensors are switched off over 20mph , so it couldn't be parking sensors.
So I took the car .....and half way home guess what beep beep beep !!
They also said there was a small switch chrome toggle in the drivers footwell, probably for an aftermarket gizmo ?
I switched it when the beeping started''''beep gone !! Bow down
So, Guy Salmon - free health check, free valet and a free bottle of Guy Salmon water.
What a bargain. Very Happy
Post #220959 5th Nov 2013 5:29pm
'smartnav'....... its a feature by trafficmaster....you subscribe and if you need directions or help when broken down they help you via this system..
have a look by the brake/accelerator pedals and you should have a speaker mounted there ..
or, it might not be this .. Laughing ... - .- -.
Post #220963 5th Nov 2013 5:49pm
steves025uk
Stan, you are absolutely right Very Happy there is a speaker by the pedals.
The switch is mounted on the trim on the left of the footwell and is easily knocked by my size 10's.
That may explain why it was intermittent.
When the weather improves I will remove the switch and tape up the wiring.
Thanks, I can take out the earplugs now.
Post #221104 6th Nov 2013 10:44am
i have the same button but mines on the right of the footwell and when i press mine you hear a dialling tone for a bit then a female voice says '' cant connect, please try again''.. ... - .- -.
Post #221105 6th Nov 2013 10:52am
hoppy
England 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
^^^^^ ,, mmmm... i often hear a female voice saying,,, cant connect... but she never says try again... Shocked free use of "RSW" all comms to anyone nearby
Post #221107 6th Nov 2013 11:31am
thats cos she doesnt like you... Mr. Green ... - .- -.
Post #221118 6th Nov 2013 11:48am
hoppy
^^^^.... Thumbs Up
wouldnt mind but shes BLIND aswell.... Shocked free use of "RSW" all comms to anyone nearby
Post #221129 6th Nov 2013 12:48pm
