Home > Off Topic > Generator advice please |
As title please chaps. We've had a power cut here today, nothing too dramatic, only about an hour but gets on my tits as I have a number of aquariums including a reef tank. Obviously power cuts don't do these things any good at all, much more than 12 hours and it creates serious bother.
3rd Nov 2013 9:14pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
Or..... Depending on the power needed to keep a tank running, what about a few of these? They come in all sizes.. It's just the theory I am meaning..
3rd Nov 2013 9:24pm |
Yep, so I have a 3KVA one on my reef tank and this will keep it running for about an hour on the supplied batteries. It's more about keeping the reactors and flow pumps going so I don't have to reset it all if a fuse pops. I'm still at the mercy of the grid though if it's out for any length of time.
3rd Nov 2013 9:33pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
Have you considered using a vehicle as the power source for generating electricity?
3rd Nov 2013 10:00pm |
BrianC Member Since: 15 Apr 2009 Location: central belt Posts: 1429 |
Mobile generators are only to be used with class 2 equipment (double insulated/no earth) you can modify a mobile generator to use class 1 equipment but it would require a earth spike. Running electrics in a house from a mobile generator/invertor is not very safe.
3rd Nov 2013 10:07pm |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
Sister's father- in-law has one that will power the whole house. It's on an auto-start after (I think) 3 minutes without power. Interestingly, he had it tapped into the gas line to the house, so it could go indefinitely if needed.
4th Nov 2013 12:30am |
OK, so it seems there is a world of difference between a proper standby generator and an emergency generator. The bit about feeding back into the grid is a rather interesting point too; I am thinking about those houses with PV and the feed back into the grid capability. That must be a nuisance for linesmen unless the grid can control them remotely.
4th Nov 2013 9:19am |
markdotreed Member Since: 05 Sep 2011 Location: Ropley Posts: 741 |
I've got a Clarke 720W Petrol generator. Won't power the whole house but it's enough to power the fridge and the freezer. Runs for about 3 hours on the tank size.
4th Nov 2013 9:38am |
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 |
Quite an expensive undertaking to do this properly. You would need an AMF panel. (Automatic mains failure). This senses the lack of mains power and signals the generator to start then when it sees that the voltage and frequency has stabilised to preset tolerances closes a contactor and this switches power from the genset through to the load, at the same time another intrinsically linked contactor opens and prevents power from feeding back to the grid. When mains power is restored the panel senses this and reverses the process and then shuts the generator down to standby mode. Not something for DIY man. Agueroooooooooo. 93-20
4th Nov 2013 11:49am |
Paul J. Member Since: 13 Jan 2009 Location: Leafy Cheshire Posts: 278 |
The inverters used with PV installations automatically shut down if there is a loss of mains power, specifically to prevent this. As you rightly identify, the installation of a generator supply is a job for the professionals. |
4th Nov 2013 11:23pm |
If you get that Lister unit (technically it looks like a listeroid) then they run on some of the worst fuels you can come across without complaint.
6th Nov 2013 2:43pm |
Budgie Member Since: 09 Jul 2012 Location: Stornoway Posts: 267 |
Is THIS what you're looking for?
6th Nov 2013 6:00pm |
Budgie, that's fantastic... That's bookmarked and on my "to do" list.. Previously..
6th Nov 2013 6:35pm |
That looks like the kiddie Sir. Ordered and professional sparkie booked to come and install it. |
6th Nov 2013 8:40pm |
