![]() | Home > In Car Electronics (L322) > Mirror not dropping in reverse? |
stuboy00 Member Since: 09 Feb 2012 Location: Glasgow Posts: 251 ![]() ![]() ![]() |
When I select reverse my passenger mirror isn't dropping now the camera comes on and the sensors also all work it's just the mirror isn't dropping? Any ideas? F**K IT you only live once |
Ah many thanks just found out her majesty was out in the car pressing buttons lol F**K IT you only live once |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3261 ![]() ![]() ![]() |
square button over to the left (passenger) side should activate it. If it doesn't, it could be it is jammed or caught on something inside the mirror housing. Mine was a bit iffy at first but manipulated it a bit and now works fine. |
Sparkylee Member Since: 15 Apr 2012 Location: Guildford Posts: 85 ![]() ![]() |
Thanks for that ![]() It bugs us because our drive is like Mount Everest and when it dips down you can't see anything Was waiting for IID tool to arrive to see if I could switch it off ![]() Just tried while waiting for SWMBO to come out of sainsburys ![]() |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8110 ![]() ![]() ![]() |
steve9bug Member Since: 25 Aug 2013 Location: sunderland Posts: 356 ![]() ![]() ![]() |
Never looked at mine but it now works |
XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4995 ![]() ![]() ![]() |
![]() 2024 RR Velar 2021 AM new Vantage |
SATVC Member Since: 25 Nov 2012 Location: Surrey Posts: 172 ![]() ![]() ![]() |
When I put mine in reverse the passenger mirror just goes mad! Left right up down??
Oe_tuning Member Since: 08 Aug 2013 Location: Singapore Posts: 37 ![]() ![]() ![]() |
Hi SATVC,
That's great, I'll give it a go. Thankyou |
stormindes Member Since: 20 Oct 2013 Location: United Kingdom Posts: 13 ![]() ![]() ![]() |
Think that the rave manual says something along these lines (and stand to be corrected- but have read it somewhere) but I gave in after a few attempts and just accept where it stops. However some days it does have a bit of a fit and can't make up it's mind where it wants to go, i just put this down to a possible connection issue and I've added it to my lengthy list of things to do ![]() door card square button does switch off this option as stated earlier in this thread tho and is more often than not the cure to the 'WTF is wrong with it now ![]() |
