![]() | Home > Technical (L322) > Radiator Electrolysis |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3981 ![]() ![]() ![]() |
I've not come across it before but just measured mine out of interest with the car "asleep" and get 0.17V. ie coolant to battery -ve terminal.
As the coolant 'breaks down with age and cycles' dirt is often picked up from within the system. this dirt as it rubs across surfaces is like a small balloon being rubbed over a wool jumper.
Old fluid is unlikely to be the problem this time though as it must've been changed when the rad was installed so would only be 6 months old. |
But if it's not flushed fully how much of the old fluid or dirt is still in there? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
DaveK - Will's questioning your flushing. |
I'm a 2 flush man myself as you know David |
....er, how would I know? |
Its ok David, we cant hide it forever |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 794 ![]() ![]() ![]() |
Had an auto spark look at the car in question and he found a reading in the cooling system that would be enough to get electrolysis going... mind you, as he went on to demonstrate, he could get a reading of the plastic trim in the engine bay !!. Several vehicles later and we had yet to find one that didm't give a reading in the coolant. Then he posed the question... how come the heater matrix hadn't been destroyed as well seeing as the aluminium in that is really thin to start with ?
