Home > Wheels & Tyres > Suspension hard after fitting winter tyres
McSchotte
Germany 2008 Range Rover Vogue TDV8 Java Black
I had new Michelin Latitude Alpins fitted 2 days a go and since then the suspension seems rock hard and I feel every bump in the road. Can a change in tyre make that much difference or have they somehow Censored the suspension? When I picked it up it was locked in access height so I don't think they put it in off-road height when they jacked it up. I've tried cycling through the suspension a couple of times but to no avail. Any ideas?
Post #221481 7th Nov 2013 4:32pm
check the tyre pressures ... ... - .- -.
Post #221482 7th Nov 2013 4:39pm
If you had tyres like NEXEN fitted before, which are soft walled, then yes the ride might feel harder.. Thumbs Up Previously..
Post #221491 7th Nov 2013 5:58pm
^ Could be this but I would check pressures and reduce them if you are a solo user. Thumbs Up
Post #221496 7th Nov 2013 6:25pm
CSK
France 2013 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Ordered the new winter Latitudes too, hope it is just the pressure. I'm waiting to fit them as I don't particularly need them right now in St Tropez! Let me know how you fare with them.
Post #221515 7th Nov 2013 8:46pm
Googsy
Try 31 front 34 rear or similar Thumbs Up Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #221518 7th Nov 2013 8:55pm
