Home > Maintenance & Mods (L322) > replacing rear shock absorbers
vnitos
South Africa 2016 Range Rover SVAutobiography 5.0 SC V8 Baltic Blue
can the rear shock absorbers be replaced separately from the air suspension bag assembly.
how difficult is it to replace?
btw it is a 2004 4.4 v8
Post #221565 8th Nov 2013 2:48am
Looks like a straight forward job on Rave
Post #221573 8th Nov 2013 7:45am
Yes, they are a separate item.
One big bolt on the rear hub (wheel off, support the lower arm), three nuts at the top end (seats forward, carpet back).
The most difficult part is getting to the three nuts at the top as these are hidden under the carpet which is very very thick and sturdy at this point. Worth spending some time removing interior trim so that you can easily raise the carpet to reveal the top of the shock absorber, otherwise you may end up ripping the carpet in frustration (words from the wise, after the act!) .
Post #221724 8th Nov 2013 9:04pm
vnitos
forgot to ask - would you use Monroe shocks or should i be looking for Bilstein or which brand would you buy - bearing in mind that I will most probably sell the car by mid-2014
Post #221789 9th Nov 2013 4:20am
I fitted a set of Monroe shocks to my Classic RR a few years ago and it was money down the drain, they were cheap and nasty and the darned RR drove like a plate of jelly. I then fitted a set of Bilsteins and the RR was transformed. If I were you I would try Dan for some genuine Land Rover shocks
Post #221797 9th Nov 2013 8:03am
wealy
Genuine every time
Post #221810 9th Nov 2013 9:44am
