Home > Maintenance & Mods (L322) > Rear track rod bolt seized advice please sorted. |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Just when I thought I would have my car sorted it appears bolt on rear track rod at chassis end is seized. Now the toe is out on drivers rear side. I thought all adjustment was done mid track arm. Anyway they showed me that despite turning the nut it only turned the bush at chassis . I even got to use my iid tool to put car into TTM Anyone know what part it is as in number I think I need to replace whole rear track rod and bolt. Is it an easy job to do ? Thanks.
9th Nov 2013 4:47pm |
Advanced Factors Site Sponsor Member Since: 31 May 2013 Location: Southampton Posts: 195 |
9th Nov 2013 5:08pm |
I need track rod tie rod that looks like droplink. I'm confused as did not believe nut at chassis end offered adjustment. See pic below might help.
9th Nov 2013 5:16pm |
Droplink (on ends of ARB) is a stabiliser link, not adjustable
9th Nov 2013 5:18pm |
9th Nov 2013 5:21pm |
Present :2008 TDV8 HSE
9th Nov 2013 5:23pm |
That is indeed a rear toe link (Panhard rod) for a sport, on my way to work in a mo to open up for a RRS user who is urgent for some bits, will try to find the number when I get there unless anyone comes up with it first Paul Redding
9th Nov 2013 5:26pm |
just had a look and mine has a toe rod like in the pic i posted, can't see anything which looks like your pic and it is the only thing which controls the toe at the rear there is nothing else connected to the hub bar the wishbones and the d/s.
9th Nov 2013 5:27pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6400 |
Googsy
9th Nov 2013 5:31pm |
9th Nov 2013 5:32pm |
I haven't a clue...... You are right northern
9th Nov 2013 5:34pm |
IMSC @ £25 each side, suggest you replace in pairs, then get tracking sorted .
9th Nov 2013 5:35pm |
gen about £50, aftermarket from 20 a side.
9th Nov 2013 5:36pm |
