Home > Technical (L322) > 2003 Vogue Drivers door wont lock/unlock with key? |
Use search, I repaired mine a year or two ago |
10th Nov 2013 12:31am |
Plant Member Since: 01 Oct 2013 Location: Wirral Posts: 38 |
Tried the search but keywords are quite specific . Any chance of pointing me in the right direction?! |
10th Nov 2013 12:40am |
Odd that coz when I searched a few threads came up that I replied to
10th Nov 2013 1:29am |
Might be an idea to put this into Wiki |
10th Nov 2013 1:32am |
Thank you, that was much more helpful
10th Nov 2013 8:29am |
Well if you're not very mechanically minded why not leave it to the professionals
10th Nov 2013 9:21am |
Because I believe in trying to do things myself, I just need to be armed with methodical instructions!.
10th Nov 2013 9:47am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16171 |
Plant, all for you doing jobs yourself my friend... But sometimes there are jobs to leave to the professionals... I personally think this is one of them... It's quite tricky & if it goes wrong! You could be seriously in the mire... |
10th Nov 2013 10:02am |
Thanks Craig, but I've fixed the key locking issue now
10th Nov 2013 10:27am |
Ive had the panel off and the cable seems to be in tact and in place. The handle is rather stiff though, I have to put my thumb on the lock to get enough force/leverage to pull the handle open. I think it may be prudent to order a spare cable in case of emergency!! |
10th Nov 2013 12:16pm |
Try opening the door, clicking the latch across with the door open (using a screwdriver) then pull the handle and see if it releases easily... If it does, close the door slowly and see if the striker on the pillar is pushing the door up or down or too far in? Can also make the door hard to open... (kind of initial jolt as the latch releases) if so, then it needs the torx bolts loosening and the striker plate aligning not too loose though or there will be lots of wind noise |
10th Nov 2013 3:11pm |
Cheers Craig, will give that a try next weekend |
10th Nov 2013 5:15pm |
Unnecessary quote removed
10th Nov 2013 5:25pm |
Worth a try |
10th Nov 2013 5:59pm |
