![]() | Home > Technical (L322) > iidtool prob |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
This sounds like one to get in touch with GAP about..... .
Is your handbrake on? Is the ignition on 11? |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35878
make sure the engine is running, that will ensure the full voltage is getting round the ecu's..
| SteveMFr Site Sponsor Member Since: 22 Nov 2009 Location: Strasbourg, France Posts: 1641 |
Your ignition goes to 11? JK - thanks for the help, Craig. Tallsaj, check the LED on the side of the IIDTool. You should see a series of rapid blinks as it boots up and then, if you press one of the cruise buttons, you should see a solid light as long as you hold the button. This not happening properly is not uncommon. The cause is usually loose pins on the female OBD connector in your RR. If you don't see the LED light when you press, send us a mail to Support @ our website and Patrick will get some pin repair pics over to you. Steve
RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
| All times are GMT |
