Home > Technical (L322) > Injector inbalance on four cylinders
mike & the mechanics
United Kingdom 2007 Range Rover Vogue SE TDV8 Galway Green
Well did not manage a month as some maybe aware! No 7 injector packed in a couple of weeks ago but last night after a five mile drive 7 then left standing for an hour on restart engine was lumpy & shook itself for a couple of miles before clearing. Plugged it in this morning & showing inbalance on 4 6 8 2 injectors. However live data shows egr valves working smoothly, turbos also smooth & all 8 injectors within limits. low 7 high fuel pressures also stable & within limits so am quite confused. Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!!
Post #222463 12th Nov 2013 9:16pm
D16XEY
Scotland 2003 Range Rover Vogue 4.4 V8 Java Black
Hi M&M
Have you checked your coil packs (one on top of each plug), I had one go and the symptoms were exactly as you describe. At first MIL light flashed and then went on steady.
D16XEY
Post #222486 12th Nov 2013 10:07pm
yes the injectors all tested ok but mine is a diesel which im starting to wish was a SC which i nearly bought instead Laughing Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!!
Post #222490 12th Nov 2013 10:13pm
Sorry but Laughing
Post #222503 12th Nov 2013 10:59pm
Arent they all on one side?
Could it be wiring related? Maybe a problem with the injector loom on that side of the engine, loose connection etc? There is nothing that can't be fixed with a hammer😜😜
Post #222507 12th Nov 2013 11:15pm
Not sure as injector numbers dont correspond to cylinder numbers apart from seven & eight I think. does any one know the corresponding injector numbers to cylinder number? lucky for me when injector seven failed it was readable on the loom Very Happy Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!!
Post #222514 12th Nov 2013 11:28pm
That sounds a bit daft Rolling Eyes
Hope you get it sorted Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #222518 12th Nov 2013 11:35pm
Have to as bonfire night has gone this year Rolling with laughter Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!!
Post #222529 12th Nov 2013 11:52pm
No probs all week but the Mother in law says dont drive it on a Sunday & it will be fine Rolling with laughter Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!!
Post #223293 16th Nov 2013 12:19am
