Home > Maintenance & Mods (L322) > 02-05 TD6 Vogue FRONT PADS GUIDE |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
12th Nov 2013 11:19pm |
Pads generally are pretty easy to change, the td6 and tdv8 arr completely different front setups, the tdv 8 having brembos.
12th Nov 2013 11:22pm |
bizzybus Member Since: 19 Aug 2012 Location: merseyside Posts: 53 |
Thanks chaps,knew you wouldnt let me down, hope it dosnt rain on sunday (SEE WHAT HAPPENS WITH HEATED SEATS) |
12th Nov 2013 11:29pm |
You shouldnt need to remove both bolts on the caliper if just swapping the pads, take one out and the caliper will swing out of the way. There is nothing that can't be fixed with a hammer😜😜
12th Nov 2013 11:32pm |
good tip thanks monkey (SEE WHAT HAPPENS WITH HEATED SEATS) |
13th Nov 2013 12:51am |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
If you don't manage to change them, blowing in the oposite direction you're traveling is just as effective as TD6 brakes. |
13th Nov 2013 12:55am |
