![]() | Home > Technical (L322) > air supensioninactive prob only have jeep2weeks |
| Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1673
What did the fault codes say or did you just clear them without reading? |
| hse 2004 Member Since: 03 Nov 2013 Location: banbridge Posts: 27
Code reader Says no fault soul this b down 2 a loose senor connection if so o u no were |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35881
whats the condition of and how old is the battery? if around 3/4 years old i would put a new one on.. ... - .- -.
^^ agreed. And threads merged again... |
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048
Prepare for a new thread
hse2004 obviously has a problem with spelling and is in a bit of a fix so it would be appropriate as conscientious forum members to try and help him.. ... - .- -.
Hear hear... I would guess maybe even English is not his first language... |
But i bet his English is better than most of your F, D, SP, NL etc etc etc (im sure you all get the point) |
If I disconnect the battery and touch positive lead 2 negative .could this work or cause a prob |
| Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700
It's ok... It will not cause a problem.... As long as the battery is definitely disconnected... |
Will try 2maro and c if it clears it.will report back.thanx |
It won't clear the fault |
Any tips |
| All times are GMT |
