Home > General (L405) > Heated Front windscreen
Saintboggart
United Kingdom 2013 Range Rover Vogue SE TDV6 Indus Silver
The front windscreen in the vogue se is heated right? Can anyone explain why the buttons are different to what is in the handbook. The hand book shows 3 buttons heated front, heated rear and max my car has only got heated rear and max ? I'm probably being thick but it is bugging me !
Post #222797 14th Nov 2013 12:48am
You will need to fill in your car profile (that means we can see what model your FF is) essential when your asking questions about your specs sir Thumbs Up
Post #222798 14th Nov 2013 12:56am
Saintboggart
I will sort that out, in the meantime 3.0 TDV6 vogue SE
Post #223049 15th Nov 2013 12:32am
5.0
Has your car got the heat reflective windscreen? On the L322 you could not have a heated screen if you had the heat reflective option.
Post #223161 15th Nov 2013 2:04pm
fairwx
2015 Range Rover Vogue SE SDV6 Luxor
If it is an L405 Vogue SE TDV6 then it should have a heated front screen, of which the button is located below the MAX defrost button on the left hand side.
One reason you may not have this function if if you have an non-UK spec vehicle.
Post #223176 15th Nov 2013 4:26pm
UK supplied car ?
Post #223254 15th Nov 2013 9:48pm
Saintboggart
Yes it is a uk supplied car
Post #223404 16th Nov 2013 9:12pm
NormanP
United Kingdom 2014 Range Rover Vogue TDV6 Aintree Green
As far as I can tell, all models UK should have all three buttons/functions. Mine (Vogue) certainly does (and it has the Solar glass as an option but that shouldn't make any difference to the heated options). First frost here this morning and it certainly clears it quickly... I'd contact your supplying dealer and query this with them. Norman
Current LR: L405 Vogue TDV6 (MY 2014) Aintree Green/ Ivory interior
Past LR: L322 Vogue 4.4 V8 (2002); Discovery series1 V8 (1995)
Post #223908 19th Nov 2013 12:27pm
Willo98
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Have you got the heating elements in the front screen? If you look closely you should be able to see hundreds of very fine heating elements running from top to bottom.
Post #224565 22nd Nov 2013 3:12pm
tboner001
England 2014 Range Rover Autobiography SDV8 Fuji White
PDI - Notice to dealers
Information icon Q334 UPS 5413-3 - Heated Front Screen Control Switch Missing [UKROW-UPS]
do not know what the contents of the info is though sorry. Far to many gone...
Post #225466 27th Nov 2013 8:17am
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
You have to wonder about letting people see bulletins like that on TOPIX. Presumably HSE bits were fitted by mistake.
Post #225497 27th Nov 2013 11:09am
Saintboggart
Turns out they forgot to install switch at the factory all sorted now switch installed
Post #229022 14th Dec 2013 12:45am
tboner001
Shocked Not Far to many gone...
Post #235653 18th Jan 2014 5:58am
Really! Wow, thought those days were gone... Rolling Eyes Embarassed
Post #235655 18th Jan 2014 6:12am
