Home > General > Is my FFRR trying to talk to me?
delamo
England 2007 Range Rover Vogue SE TDV8 Tonga Green
After purchasing a couple of new iPhone4s I have been setting them up to my home wireless connection etc...
When connecting the iPhone to the Wi-Fi at home, on the screen - included in the list of available Networks (my standard home connection and my those of my neighbours) - is RAROTONGA which must mean my car sat on the drive outside (RangeRoverTonga Green)?
Despite having these new fangled phones - I am not in the least bit techno minded - so what does this mean I can do with it? - is my pride and joy trying to talk to me?
Post #22223 13th Jul 2010 2:43pm
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
Laughing Laughing Laughing Laughing
No because there's no GR. If it was it should read RAROTONGAGR..... Mr. Green Mr. Green
Post #22238 13th Jul 2010 5:08pm
delamo
Question Neutral
I have the same network listing (RAROTONGA) available on my laptop Wi- Fi connection options also?
Is it for a Bluetooth connection ? ( Whistle not that I have the slightest idea how that all works either! )
daveo - you appear to be this sites leading techno expert - any suggestions you could offer to help me?...please Thumbs Up
Post #22240 13th Jul 2010 5:30pm
daveo
hi, all i can think is that your phone is looking for compatable connection, now is rarotonga your blue tooth idon the car.
now my phone wont pick my car up unless the ignition is on but are your saying that you are indoors,your car on drive and it is still picking it up.. V8 facelift Range Rover Autobiography 22" wheels.
Post #22248 13th Jul 2010 8:42pm
The phone would not pick up the car unless the key was in the ignition and at position 2.
The blue tooth connection to all Land Rovers is just called Land Rover, which you may be able to change in your phone's settings to Range Rover - I can't see how to do this on the iPhone though. Discovery 4 HSE
Post #22255 13th Jul 2010 9:15pm
daveo
i can set the blue tooth id to any thing i want using navcoder. i am wondering if your cars id is in the iphone's list from a previous scan and connection and when you are serching from indoors it will still be there becouse if it was live it would connect to it... V8 facelift Range Rover Autobiography 22" wheels.
Post #22257 13th Jul 2010 9:34pm
Fox
Could it be because after using the car you have not moved the phone very far from it?
When I park at work and switch off, my phone does not disconnect until I get into the office about 20m away.
Then I get the beep to tell me it's disconnected.
Post #22259 13th Jul 2010 9:59pm
delamo
Thanks for your responses daveo and RRUK (Edit - and Fox)
Rolling Eyes even more flummoxed as to what signal it is picking up Question
Regarding the ignition position - the car is locked and the key is in my pocket (so to speak).
I have never set up or used the bluetooth equipment on the car before - using this phone or any other phone...
I am this vehicles second owner.
Using the iPhone, or laptop - if I select RAROTONGA on the list, it requests a password (which I do not know ?)
Curiouser and curiouser...
If it isn't a bluetooth thingy - could it maybe be a tracking device of one kind or another from the previous registered keeper (LandRoverUK)?
It is obviously picking up a Wi-Fi signal of one kind or another as RAROTONGA shows a reasonable signal strength
Shocked AM I BEING WATCHED!!!
Post #22260 13th Jul 2010 10:09pm
I had my honeymoon in Rarotonga, a beautiful island in the Cook Islands in the South Pacific.
I know that doesn't help but that might be where the name comes from?
http://www.ck/raro.htm Discovery 4 HSE
Post #22261 13th Jul 2010 10:29pm
delamo
Laughing You are absolutley right RRUK - That doesn't help at all Thumbs Up
Just discovered the signal gets stronger as you approach the car - What the Censored Censored is going on Question Question Question
Post #22262 13th Jul 2010 10:37pm
The code is 2121 try it....... Thumbs Up
Previous owner called connection RAROTONGA and phone picked this up when you were in car with ignition on even though you did not connect your phone has listed it.
Next time your in car try the 2121 code to connect then set phone setting to connect automatically and to "Trust" the RAROTONGA connection....
Easy Very Happy
Oh and you can connect when the car is off mine often does when the phone rings near the parked car! Very annoying.
Post #22266 13th Jul 2010 10:54pm
delamo
Sad No such luck Gazellio - the 'Password' on the iPhone screen needs to be 8 characters before the JOIN button turns blue and submits the code - message comes back - Unable to join the network "RAROTONGA" - Dismiss
(tried 21212121 but that don't work either)
Where does this suggestion of yours originate from? - how would you know what the code was likely to be? - What do you know that i don't ? Confused
Post #22267 13th Jul 2010 11:10pm
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
It's in the handbook I think
Post #22268 13th Jul 2010 11:15pm
ALL LAND ROVERS use the 2121 code to connect a handset via the Bluetooth Module.
You are trying to connect to Bluetooth using the WIFI connect tools on you Iphone.
You need to navigate to BLUETOOTH then try to connect with the car using 2121.
No idea why you WIFI search is picking up that RARATONGA connection.
Post #22287 14th Jul 2010 9:43am
If its a wifi connection it is picking up then its NOT the car! Someone close by must have a wifi SSID of Rarotonga.
The password you are looking for is the WEP key. If you have a laptop with wireless try sniffing for wireless networks and see if it pops up there too. Discovery 4 HSE
Post #22289 14th Jul 2010 9:50am
