Home > Wheels & Tyres > range rover tdv8 vogue tyre pressure
mbdj
hi could someone confirm tyre pressures for standard 19 inch alloys front and rear thanks. Question
Post #22297 14th Jul 2010 11:17am
It's on the sticker inside the door shut of the drivers door, use your eyes! Thumbs Up Discovery 4 HSE
1993 90 Tdi
Post #22300 14th Jul 2010 11:36am
mbdj
thanks for your quick reply will check thanks.
Post #22304 14th Jul 2010 11:53am
However......
The sticker shows a wide range of pressures depending on number of occupants but only quotes 2 plus luggage and five plus luggage.
For everyday use you can go down a bit for a better ride IMHO. I use as low as 34 front 36 rear in winter conditions. Thumbs Up
Post #22314 14th Jul 2010 1:37pm
supermario
Whats the reason for having lower pressure on the front? Just wondering thanks
Post #158671 20th Dec 2012 10:46am
Bomber County
England 2007 Range Rover Vogue TDV8 Java Black
for what it's worth I was told by someone on the forum that 36 front and 42 rear was the best pressure for my TDV8 on 19's.
I've stuck to that and I find it works just fine.
I'm sure there's an array of opinions on this matter though!
Cheers, Bomber. - Ad augusta per angusta -
Post #158687 20th Dec 2012 11:50am
There is only 1 way to find out the correct pressure for your tyres in your typical use and thats the chalk method... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #158697 20th Dec 2012 12:40pm
Lower pressure on the front as the weight over the front axle doesn't change with load where as the rear has a full tank of fuel sometimes, full boot and pulling a large load which could exert upto 150kg weight extra.
BC's quoted pressures are what i run which are the towing/heavy load pressures which are great for improving MPG and handling, but reduce overall grip. Fine if you spend your time doing a lot of miles. When the weather comes in the tryes will break away that bit more quickly due to a reduced downward force from the outer edges of the tyres. Lowering the pressure will improve this but increase fuel consumption but also make the ride a little more compliant Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #161160 2nd Jan 2013 10:23am
TeeMyob
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
I increased mine to the full load and gained 3 mpg
I also use nitrogen as I have access to it through my business
Post #522920 26th Jul 2019 11:43pm
makes sense...more pressure will give you less rolling resistance and therefore slightly more mpg.. ... - .- -.
Post #522939 27th Jul 2019 7:24am
