![]() | Home > Maintenance & Mods (L322) > Towing socket charger adapter - Any Experience ? |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1201 ![]() ![]() |
Anybody used / using one of these - available from the Forum Shop ? -
oldcro Member Since: 17 Mar 2012 Location: Shetland Posts: 359 ![]() ![]() ![]() |
I bought one for use on my FFRR (although it would fit any vehicle with a suitable socket) and a CTEK charger, it is an excellent tool and highly recommended. |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3957 ![]() ![]() ![]() |
I made one up and find it very convenient, I can charge the FF with it s bonnet shut and doors locked so if the worst happened you can't be locked out by a flat battery as you connect to it externally. When I contacted CTEK they said they don't recommend this setup due to the cable length involved but I haven't had any problems other than the battery never shows as fully charged even when left overnight.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3986 ![]() ![]() ![]() |
If you have towbar electrics the adapter is an excellent idea combined with a Ctek MXS-7 or 10 charger. |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1673 ![]() ![]() |
Thoroughly recommended, obviously |
Not biased then, Martin |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
^ I did that with our caravan once. I had it plugged into the socket on the side of our garage and just plain forgot to remove it. Thankfully it broke at the garage end and the caravan socket was ok... Previously..
Yes they do |
I was only joking ! - but glad the notice comes with it . . .
bigdave Member Since: 27 Jun 2011 Location: Cornwall Posts: 274 ![]() ![]() ![]() |
Used mine today on my D3.
I love a happy customer |
I made mine before I saw these or I wouldn't have bothered |
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 457 ![]() ![]() ![]() |
I looked into making one up and then decided it was too much faff and bought Martin's and I'm glad I did.
andyleeds Member Since: 31 Dec 2010 Location: west yorks Posts: 982 ![]() ![]() ![]() |
This probably sounds stupid but what does the other end plug into? The mains? |
