![]() | Home > Maintenance & Mods (L322) > Gearbox service. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16372 ![]() ![]() ![]() |
If doing the job at home? Jack car up safely and level, first loosen filler bung before loosening the drain bung (no point dropping the fluid if you cannot get any back in!) drop fluid, change sump, refill then run the engine and go up and down the box 10 times allowing the fluid to A, to circulate and B, to warm up... Leave engine running with gear lever in P or N & Fill until the fluid just starts to trickle back out of the filler...
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Cheers craig. Will probably give it a go.
No need to remove anything to change the sump... It's very very simple to do |
Yes sorry My bad, just looked closer, its only for cars with a DPF....... apparently,
is the pan supposed to come with a Gasket, it seems to have a built in rubber seal, but looking on Microcat it seems to show a gasket included in the kit?
