![]() | Home > Maintenance & Mods (L322) > Towing socket charger adapter - Any Experience ? |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
Is it the same connection as an optimate?
I made one up (just for the hell of it) with croc clips at the end, mated with a Ctek MXS7. Works a treat.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35827 ![]() ![]() |
keep it in your handbag Tim.. |
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1200 ![]() ![]() |
Just realised I bought one of the Lidl chargers for my Caterham last winter - I wonder if that is compatible with one of Martin's adaptors . . . . ?
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
I've got a couple of the Lidl chargers as well but they are unfortunately not compatible with Martins adapters.
Correction, there is a way to do it if you are prepared to cut the battery terminal clips off the Lidl charger.
^ Thanks for that - I'm not sure of the output of the Lidl charger ? - I'll have to dig it out of the garage
The instruction manual states it is suitable for batteries upto 120Ah.
silversurfer Member Since: 24 Oct 2013 Location: londinium Posts: 84 ![]() ![]() ![]() |
So in the event that you find yourself locked out and unable to open the vehicle (flat battery) is it possible to connect up a battery to the tow bar socket and open the vehicle.?
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8106 ![]() ![]() ![]() |
Yes - you can wire up a battery to the tow socket & then open the doors.
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1673 ![]() ![]() |
Yes I do an Optimate version (for either type of connector) - www.fullfatrr.com/shop |
The Lidl charger would require a connector of some sort adding to the leads as they have only ring terminals on the end which go straight to the croc clips.
drivesafe Member Since: 19 Mar 2008 Location: Gold Coast Posts: 126 ![]() ![]() ![]() |
Hi Martin and can I make a suggestion.
I haven't but then I've never been asked for one |
