![]() | Home > Technical (L322) > How long to fully charge a battery. |
| supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3965
I've been thinking about my problems (with car that is |
All understood BUT given that I've given the battery a bit of a knock starting the car will half an hour put it all back given that the alternator is meeting the needs of the rest of the car when its running. I know they are good compared to dynamos but the current they can generate is not infinite - is 30 minutes enough? Geoff |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35885
i think its a characteristic of the range rover that the battery goes flat for no reason..
Thanks Stan,
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989
If the battery is in good condition and is capable of starting the engine without any fuss I would have thought a 30min run with whatever you have switched on as well would be perfectly adequate. I've never had a problem with a car not keeping up with the batterys needs whilst using it 1/2 hour each day in the depths of an Edinburgh winter for 20 years where I can guarantee "everything" was on morning and night.
your theory is probably correct NDFI if you get in your range a drive off straight away but in practice its ,unlock the doors , wait for the wife to change her dress/shoes/coat yet again and meanwhile the ecus are buzzing away for about 20 minutes draining the battery..if this scenario happens many times then i can see how the battery looses its state.. |
Coolio thanks both,
I've just realised that I've been taking advice off David Cameron and Mr Bean |
I have to admit with the FFRR I do start the engine when I first open it to go anywhere irrespective when I subsequently leave.
| drivesafe Member Since: 19 Mar 2008 Location: Gold Coast Posts: 126
Hi Geoff and the problem is that you will never drive long enough to fully charge a lead acid battery from an alternator.
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
Last winter mine was coping well with running the FBH for 20mins before a run and then a 15min drive to work with the seats and windows on as well as the lights and the radio.
Currently (no pun intended) the car is on charge using the CTEK and will be left the rest of today, all night and all tomorrow. That should allow sufficient "float" time for the battery to fully charge.
| Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947
| All times are GMT |
