Home > Maintenance & Mods (L322) > Rear light problem |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34920 |
i would have said a bad earth problem....have you changed the bulb... ... - .- -.
14th Nov 2013 5:23pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
As Stan says trying swapping bulbs over and see if symptom arises on other light unit. Present :2008 TDV8 HSE
14th Nov 2013 5:24pm |
Squaresausage Member Since: 09 Nov 2013 Location: Hamilton, Lanarkshire Posts: 22 |
Yes changed the lamps, any idea where the earthing point is? The strange thing is the lamp starts bright then dulls down. What has fallen off today:-) |
14th Nov 2013 5:44pm |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
Sounds like a bad connection - Try checking with a voltmeter |
14th Nov 2013 5:54pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
It's possible you have an earth fault in the bulb holder or adjacent mounting.
14th Nov 2013 9:50pm |
I've changed the lamp holder but the problem is there, going to see if I can get a wiring loom changed as the earth points seem ok. Got a good diagram from V8 saint on another forum. What has fallen off today:-) |
18th Nov 2013 10:16pm |
