Home > Maintenance & Mods (L322) > brakes
Ukdave104
United Kingdom 2011 Range Rover Vogue 4.4 V8 Rimini Red
Mine got Brembo brakes fitted as standard. Having new pads fitted next week, a little over £500 for the lot, hate to think what the cost will be if it needs disc's too Shocked
2011 Range Rover Vogue 4.4 TDV8, Mine........ALL mine.
2012 Freelander 2 HSE SD4 - Mrs UkDave's new toy
2007 Freelander 2 GS TD4 - gone
2010 Discovery 4 XS - gone
2008 Discovery 3 HSE - gone
Post #223989 19th Nov 2013 9:08pm
Shocked
Gen pads from dan are about 80 for the older style brembos and about double for the 6 pots on the later cars!
Did my front discs and pads for £200 and the rear pads for another 30 Thumbs Up
Easy job with no special tools required. There is nothing that can't be fixed with a hammer😜😜
Post #223992 19th Nov 2013 9:40pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Indeed pad replacement is dead easy - it's a dealer con Whistle Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #223996 19th Nov 2013 9:57pm
ksskaret
Norway 2010 Range Rover Autobiography TDV8 Santorini Black
Whar kind of torx Are there for the caliper bolts Question Range Rover TdV8 Autobiography MY2010
Defender 110stw Td5 MY2006
Post #224004 19th Nov 2013 10:25pm
dave699
England 2007 Range Rover Vogue SE TDV8 Stornoway Grey
Just today quoted £225 for front pad replacement, from main dealer.
Car went in for a squeal which sounds like the rear wheel bearing to me.
Less than 100 miles ago, all the brakes were off the car for cosmetic stuff.
Replaced the full rear brakes £275ish for the parts rear discs/pads /park brake shoes / sensor. All genuine parts from Dan.
I said I would replace the pads they are blaming for the noise then take it back to them, so they can reach the conclusion that it is in fact the wheel bearing Whistle
Needless to say I ordered some genuine front pads from Dan for a little over £100 delivered.
Had it, loved it!
2007 Vogue SE TDV8
Stornoway Grey / Ivory
Climatic Seats, RSE, AFS, Deployable steps, iPod kit.
Post #224009 19th Nov 2013 10:41pm
johnboyairey
one thing not to put on yr FF (if you don't have brembo's,) is the so called 'performance' slotted/drilled discs. previous owner fitted them, they are horrible when slowing at high speed. all the grooves resonate through steering and pedal. -on my de-clutter list for the spring.
Post #224013 19th Nov 2013 11:16pm
dave699
I always stick to Genuine parts for brakes, service items and belts.
Have done on every car I've owned.
Had it, loved it!
2007 Vogue SE TDV8
Post #224014 19th Nov 2013 11:21pm
wealy
Me too
Can't go wrong with what LR designed it as!
Post #224025 20th Nov 2013 12:05am
That was my theory too, and i agree on brakes, but for the other parts i order i am keeping a note of who makes them then can order the OEM parts from the same manufacturer.
So far:
Drop link - lemforder
Front suspension Arms - lemforder
Gearbox filter - filtrans
Front pads - brembo
Front discs - assuming brembo
Reqr pads - trw There is nothing that can't be fixed with a hammer😜😜
Post #224039 20th Nov 2013 8:38am
