Home > Technical (L322) > Air suspension / ABS issue
I8A Jeep
South Africa 2003 Range Rover HSE Td6 Buckingham Blue
Hi all, I wonder if anyone can cast some light on yet another problem with my 2003 TD6. Big Cry
Although there are no warning lights or messages appearing on the dashboard, the suspension on the drivers side front keeps dropping for no apparent reason. I have left the vehicle in 'off road' height overnight and the suspension will stay level and inflated, so I dont think its the actual airbag itself. however, on occasion when i stop, the corner will deflate to the bump stop, and even sometimes while driving you can see that the corner is down. It seems though that the ECU cant detect and correct. Using the manual height adjustment will bring things right again, but only temporarily.
Coupled with all this, I have (i am sure) a related problem in that unless i brake gently, the ABS kicks in on the front drivers side wheel.
I havent put the car on autologic yet, and I guess this may provide some answers, but in the meantime, i'd be interested if anyone had ant thoughts on what the issue(s) might be?
thanks. Gray.
Post #224122 20th Nov 2013 4:55pm
paul271
Scotland 2002 Range Rover Vogue Td6 Epsom Green
Could it possibly be a wheel speed sensor?
You'll get a far clearer picture once it's been on some sort of diagnostic.
Post #224138 20th Nov 2013 7:01pm
Most likely the ride height sensor in the front corner reading incorrectly and causing the suspension to think its high in that corner and drop the suspension accordingly.
It may or may not throw an error code as it may he getting some reading from the sensor.
Dont know how that would be related to the wheel speed/abs sensor though sounds like that may be scoobied too. There is nothing that can't be fixed with a hammer😜😜
Post #224149 20th Nov 2013 7:41pm
paneldamage
I think the bags leaking...it's exactly what mine was doing before the bag popped off, followed closely by the opposite side bag.
Post #224186 20th Nov 2013 10:49pm
SteveMFr
Site Sponsor
Sounds like a pretty big leak - which should be audible or at least very visible with a spray bottle and some water+detergent. That will be the cause of the ABS kicking in as well.
Once you've located the leak, look for these in RSA and replace both fronts:
http://www.island-4x4.co.uk/suspension-par..._2839.html
Do NOT buy from a stealer...
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #224259 21st Nov 2013 10:27am
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
But please be so kind, and order the DELPHIS, because with the cheap DUNLOPS other problems come back after one year, you will remember my words..., and clean your sensors in front. The DELPHIS became more expensive this month, I believe 30 GBP each.... Wink) L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #224321 21st Nov 2013 5:37pm
sorry off topic but i'll be in dusseldorf for the xmas markets in december Meerbusch, i'll look out for your range.. Wink ... - .- -.
Post #224336 21st Nov 2013 6:27pm
Meerbusch
Hi, what a fine news!! Of course I will invite you in Düsseldorf, it is my hometown, 3 miles from MEERBUSCH, please write me, when you arrive, will make a pick up service at Airport for you of course! (with my RR) Best rgs, uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #224341 21st Nov 2013 7:02pm
i'm driving there in my range Uli... Thumbs Up ... - .- -.
Post #224358 21st Nov 2013 8:03pm
Meerbusch
Fine, will see the car on the KÖNIGSALLEE? Ask for the coffee-house: BROT & BUTTER on the road: Steinstrasse, best adress near the KÖNIGSALLEE, happy to invite you... L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #224391 21st Nov 2013 10:13pm
Post #224402 21st Nov 2013 10:36pm
Meerbusch
Also very fine: "Leysieffer" or "Heinemann" on KÖNIGSALLEE, give PM when arriving at Düsseldorf! Uli L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #224405 21st Nov 2013 10:43pm
wealy
Did you sort this Gray?
Post #231606 27th Dec 2013 3:34pm
