![]() | Home > Technical (L322) > Blue smoke |
Was it oily looking? Do you think there might be oil colecting on somthing hot, obviously I'm no expert but blue smoke can mean burning oil. 2008 MY Supercharged
kin Member Since: 20 Nov 2008 Location: rainy city Posts: 348 ![]() ![]() ![]() |
It smells of diesel rather than oil ![]() |
Obviously it's dark now and damned hard to replicate the same situation but my first thoughts would be with a small amount of oil on somthing hot, ie a large amount of oil makes alot of smoke, but any smoke must mean somthing! Mind you was it cold?only it's 10 degrees hear and blowin a gale and I forgot it's still baltic south of here. 2008 MY Supercharged
Soupdragon Member Since: 24 May 2008 Location: Norfolk Posts: 57 ![]() ![]() ![]() |
Not sure where the fuel line runs on a RR but if it's sprung a leak and the fuel is dripping onto the exhaust that could cause the problem perhaps? At least it doesn't have the same fire issue as petrol! Rules are made for the obedience of fools and the guidance of wise men. |
I had a good look underneath today, but could not spot any leaks |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6381 ![]() ![]() |
My Dad's had a split in a fuel line, if you had one its unmistakable, the smell of diesel was overpowering, plus lots of smoke coming out of the OSF wheel earch and through the bonnet area. guess it depends on where the leak is though Discovery 4 HSE
Great ![]() TBH, not smell or seen anything since.... ![]() |
