![]() | Home > Technical (L322) > TDV8 Head gasket failure / warranty |
| DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027
I had this happen in Africa. When you lose your coolant the temp gauge is effectively measuring the air temperature - not a great solution. However the check coolant warning should trigger first (if you are lucky). Running a V8 at 2000rpm with no coolant will not end well....
| Jim_m_kidd Member Since: 03 Oct 2012 Location: Yorkshire Posts: 69
If you can get it fixed then do that. Then small claims for damages, same timeframe as rejection but less inconvenient /risk |
hmm just reread that and didn't answer your question regarding the £3k storage. H'mmm not sure on that... |
| Prop Member Since: 26 Sep 2012 Location: Gloucestershire Posts: 675
XJR, glad to hear that the independent engineer report found you had no blame in the engine failure.
| mike & the mechanics Member Since: 08 Sep 2013 Location: Lincolnshire Posts: 178
You could possibly negotiate repair of your RR with the garage in question & ask them in return to wave storage then claim against warranty/dealer for cost of repair. To me that would be easier & far less stressful. maybe even offer to supply a good used unit/new/reconditioned. Any business would rather come to a conclusion that everyone walks away happy than risk of court action etc. Worse things happen at sea! Well thats what swmbo said when WRENS came to sea!!! |
| wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020
3 grand storage?????
| RR8701 Member Since: 11 Aug 2011 Location: East Ayrshire Posts: 380
Hi XJR,
| pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218
@xjr264:
| All times are GMT |
