Home > Maintenance & Mods (L322) > Would like some comments from FFRR owners - paintwork
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hi all
Ive just posted a couple of questions on detailing world in the hope that the pro detailers on there can offer some guidance but i would also like to here from FFRR owners too please?
Post links below
http://www.detailingworld.co.uk/forum/showthread.php?t=324097
http://www.detailingworld.co.uk/forum/showthread.php?t=324096
Thanks
Carl
Post #224786 23rd Nov 2013 2:34pm
Pfazz
2019 Range Rover Autobiography SDV8 Loire Blue
Can't open the pics without being registered to that site. Sad Sad Agueroooooooooo. 93-20
I swear you will never see anything like this ever again....watch it..drink it in.
Post #224788 23rd Nov 2013 2:49pm
carlos50
My apologies, didnt think about that.
Post #224794 23rd Nov 2013 3:18pm
Normally the paintwork is fairly robust, barring the wheel arches at the rear. I would report this to your local MD as soon as possible and get it repaired.
LR has a 6 year anti corrosion warranty, so the pitting and corrosion around the rule filler should be sorted under warranty, as you have a 2010MY, Not too sure what has happened where the rear spoiler and roof don't match up, however I would try and get LR to sort that too whilst they are repairing the corrosion to the filler. Don't go and try to rectify it yourself, they will most likely test paint thickness etc to check for poorly repaired accident damage, so keep it original, take pics, go complain!
Find out if your local MD has a body shop or not, ours doesn't so the reports go to LR from a very flashy body shop called Chartwells (bentleys, ferraris etc) and they are separate from LR so really are more interested in getting the work, so more likely to report in your favour! There is nothing that can't be fixed with a hammer😜😜
Post #224797 23rd Nov 2013 3:29pm
carlos50
I didnt buy from MD, will that matter?
Post #224798 23rd Nov 2013 3:31pm
Shouldn't matter either way, the corrosion warranty is 6 years from date of delivery/purchase by the original owner, irrespective of how many times it is sold on and by whom.
Has it got a full LR service book? Sometimes they will ask to see the corrosion inspections from the services but tbh its unlikely and its worth a shot, I am having the entire boot assembly replaced on mine next week, 57 plate, FOC, and they haven't asked me for anything, and it was only a tiny teeny bit of rust.
Ask your local MD which body shop they use and see if you can take it direct to the body shop to have a look at There is nothing that can't be fixed with a hammer😜😜
Post #224801 23rd Nov 2013 3:39pm
pld118
Check your service booklet as when the car is serviced there are entries meant to be filled in to confirm that paintwork inspections were done. If not done, this might be a reason for a paint warranty claim to be rejected.
Edit - hadn't seen NMJ reply Thumbs Up
Post #224802 23rd Nov 2013 3:42pm
carlos50
It had that last year by a LR MD but the supplying dealer this time just stamped the left hand column, if done last year will that be sufficient? I don't think my local MD has a bodyshop so will call them on Monday and see who they use.
Post #224805 23rd Nov 2013 3:57pm
there is a corrosion check on the maintenance schedule so if its been serviced by a MD then they would have checked it.... ... - .- -.
Post #224807 23rd Nov 2013 4:04pm
I wouldn't mention it to the body shop or the dealer let them make their own assessment and submit the report to landrover. There is nothing that can't be fixed with a hammer😜😜
Post #224808 23rd Nov 2013 4:09pm
pld118
The type of questions your post raises for me (apologies if I've got the wrong end of the stick) are:
Has the car been in 'a bump' or had a new parts/ paintwork, hence the reason for the 2 differing colours and the oxidisation near the fuel filler?
How many keepers has the car had?
Could you not:
Contact the servicing main dealers who have worked on the car; and/or
Contact the prev keeper; or
Get the selling dealer to contact the last keeper (e.g if only 1 previous owner), all of these sources being people who between them should be able to answer these simple questions such as has the car had paintwork done around the fuel filler and/or the roof spolier/ has it had a new spoiler and if so, why was that and who did the work?
It shouldn't be difficult to get the continiuty on such a new car and then you might have options for repair and resolution that might include:
LR warranty claims; or
If resulting from work done done by non LR but within some warranty period for that work, you could ask whomever did it to make good; or
You've only just got the car and whilst it could be argued that you had the chance to 'spot' these issues before buying, you've paid a lot of money for a car that has issues in need of rectification and they appear to have pre-existed before you bought. Your selling dealer might say you should have raised these issues before buying but on the other hand might be sympathetic and prepared to rectify these issues.
Just some thoughts.
Post #224812 23rd Nov 2013 5:08pm
carlos50
Hi, thanks for the comments. I will trace the history of the car through dealer network and the 2 owners. I haven't got the logbook yet so will do it once that arrives.
I washed it this afternoon and can see iron spots in hard to reach places so think the supplying dealer probably had the main body machine polished to remove as much as possible, hopefully not doing the spoiler which is now a little less white than the rest of the car.
I washed inside the filler cap and the spots are surface so will have it checked so its on record with LR then remove them and keep a close eye on it short term whilst LR consider their response.
The car has has a small paint repair in the passenger side corner of the rear bumper as I have found a fine paint line in the seal between bumper and body, but that's all I have found.
Post #224818 23rd Nov 2013 5:54pm
pld118
Well, if all of the oxidisation comes off, Iron X does claim to remove contaminants and prevent further damage to paintwork by stopping the spread Thumbs Up
** Iron X is not supposed to be used on areas of paintwork that has had a smart repair.
Post #224880 24th Nov 2013 8:29am
