![]() | Home > Maintenance & Mods (L322) > How to add LED lights? |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
You need the interface lead and the software, do a search for Navcoder, there should be plenty of info about it. 2006 Mercedes CLS
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
thanks ![]() |
dave, unfortunately at the moment i'm still looking for a ffrr but if you still have this cable when i get one then i'll have it of you .. |
darrenmax Member Since: 20 Apr 2010 Location: antwerp Posts: 420 ![]() ![]() ![]() |
check out the daytime running lights on this truck, maybe you could remove the foglights and get these to fit ?
i suppose you could always use the cornering lights below the indicator,it has the side light in it as well [if not used like mine] and fit a super bright 9 led bulb there as a daytime running light
are these cornering lights standard dave? if not then the fogs are still the best bet me thinks... |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
Did you try the brighter setting? Also - as I want to enable DRL what do I need to set a 2003 at for the E module settings or do I just "read" first and it sorts its self in Navcoder? Don't want to enable them and find I've activated the ejector seat by mistake ![]() |
Haven't tried a brighter setting yet, It's been raining every time I've had a spare 10 mins, sod's law!
DRRS Member Since: 25 Feb 2012 Location: Scotland Posts: 2 ![]() ![]() |
Hi, new to forum and new to using forums too!
salb Member Since: 25 Feb 2012 Location: blackburn Posts: 332 ![]() ![]() ![]() |
Hi guys
