![]() | Home > Maintenance & Mods (L322) > Rust convertor |
mike & the mechanics Member Since: 08 Sep 2013 Location: Lincolnshire Posts: 178 ![]() ![]() ![]() |
Waxoil has a rust inhibitor in it & I have treated every car that I have owned & have never had any corrosion probs in 20 years of driving |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 419 ![]() ![]() |
If you can find it Loctite 7500, the non industrial version is 'Rust Remedy' available from most motor factors.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6421 ![]() ![]() |
I use Kurust, sounds like it does the same as "Rust Remedy" above. Preparation is important, remove all loose rust and paint, sand down or wire brush on a drill back to good metal then apply the inhibitor/fixer. Then let it do its stuff, then prime and paint, and/or waxoyl. .
paul271 Member Since: 19 Oct 2013 Location: Aberdeen Posts: 502 ![]() ![]() ![]() |
Cheers guys. Would it be ok to spray it on?
My advice is if you live north of the border get your underside Waxoil'd ASAP.
Surprisingly cold (<4C) stops rust forming but I would agree with the salt and wet problem.
It's definitely the salt guys.
steve9bug Member Since: 25 Aug 2013 Location: sunderland Posts: 356 ![]() ![]() ![]() |
Just done all mine with worth rust convertor in a spray bottle it's water based drys gloss black. Then mixed one tin of shuts with 4 parts wazoo and coated the full underside ready for MOT next month |
