![]() | Home > Technical (L322) > 2010 MY- where is the FBH located |
ksskaret Member Since: 27 Oct 2013 Location: Tromsø Posts: 73 ![]() ![]() ![]() |
Im struggeling to locate my FBH, apparently its supposed to be in the engine room some where |
You mean it's on the left hand side of the car? ![]() |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8765 ![]() ![]() ![]() |
Confused |
From the front are you left or right handed? |
Sitting looking out from the drivers seat........with the wheel infront of me..........
Thank you for your replies |
What about when you're looking from the front? |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 ![]() ![]() ![]() |
Mine had the same issue but I cleared the fault codes and it fires up nice and toasty again now |
Really? Did they change that? Earlier L322s had the FBH on the passenger side - i.e. RH for a LHD vehicle. So for the 2010 > it was left on the LH side for both versions? Learn something new every day... ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
Steve, will according to TOPIx LR workshop manual it is the same side for the 2010MY. But by all means I could check again |
CSK Member Since: 15 Oct 2010 Location: St Tropez Posts: 750 ![]() ![]() ![]() |
I have my car in because I encountered exactly the same problem, FBH is working (the fans are blowing) but no hot air is coming out. Dealer says it needs a new FBH so a new system has been ordered. |
They seem to treat is a whole part, and dont break it down into components, so if its not working a MD will order and fit a new one.
I don't know how it is in the rest of Europe, but in Germany most Bosch service centers are also specialized in FBH. They are very serviceable - and quite simple. In Germany, there are numerous additional FBH specialists in every larger town as well. But then, Germany is the home of the FBH so it might be different in other countries...
I agree, having seen how they are put together there really isn't much too them! There is nothing that can't be fixed with a hammer😜😜
