![]() | Home > Maintenance & Mods (L322) > Which diag tool is for me? |
You can do what you want with the RSW (but it would be a bit of a fiddle and kludge) much easier with IIDTool but if your message display is borked you will have problems.
MikeG Member Since: 14 Apr 2013 Location: Netherlands Posts: 182 ![]() ![]() ![]() |
+1
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
Bluetooth IID tool? think that would work as it could display on your phone rather than dashboard 56 TDV8 Vogue SE
Bluetooth version not available for an '04 according to GAP site:
paul271 Member Since: 19 Oct 2013 Location: Aberdeen Posts: 502 ![]() ![]() ![]() |
I've just purchased a Blackbox solutions Faultmate FCR. I'll let you know it goes. |
If you get upto jn14 on the M5 your welcome to come and have us take a look ![]() |
greasemonkey1 Member Since: 22 Sep 2013 Location: london Posts: 157 ![]() ![]() ![]() |
you have no lights on the eas because your e.c.u is on lock mode,your most probably riding at the lowest setting at the moment or whats called bump stops,your suspension air bag is not filling up due to the compressor not working so the weight of the range is resting on the bump stops..don't take my word for it but only way round of a lock mode is a L.R visit and a hook up,where the compressor can be re coded and all the fault code removed,but if the compressor is at fault then few months down the line you're going to be back in the same place again,best thing would be to get a 2nd hand recon unit or a new one from L.r with a new relay and get them to re code the new compressor up,your old unit will be taken in as a surcharge...its human nature to try and fix what sometimes we think is an easy fix but no such thing when it comes to the range rover,more like a temp fix,if its broken bite the bullet and replace it or the head ache will be back... |
Thanks for the kudos, guys.
Hi Paul, If reading and clearing codes is what you are after, it will go quite well, I am sure. BBS has solid products. But comparing the IIDTool to the FCR is a little skewed: the FCR reads and erases fault codes. The IIDTool is a full diagnostic system that reads and clears codes, shows live values, controls outputs, performs service routines, edits the car configuration file CCF, flashes SW, etc. There is actually very little that separates the IIDTool from the BBS Faultmate MSV. And the differences are shrinking each day... To see in detail what can be done, enter your vehicle in the functionality list and click the down arrows in the chart to open sub-menus: http://gap-diagnostic.com/products/iidtool.html If you have any questions, feel free to PM or mail (support at gap-diagnostic dotcom) Steve ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
Happy to be corrected there Steve |
All very true Steve. But at the moment, I'm skint & the Faultmate was only £100! If you can do me one of yours for that price then I'll go and fire up the paypal account right now! |
sikegan Member Since: 21 Aug 2011 Location: Limerick Posts: 4 ![]() ![]() ![]() |
Well I bought the All Comms from RSW and Storey Wilson has really updated the software was able to sort out my suspension issues and many other faults paid for itself 10 times over would highly recommend |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
I was surprised to see his update. I thought he had given up on it. Having said that, I note the update has removed the Discovery and P38 fault find. Sneaky! |
