Home > Maintenance & Mods (L322) > rear heater
andyleeds
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
rear heater
hi everyone i have bought a rear seat resistor for the car as the blower is either on or off and i think that the resistor has gone. has anyone fitted one of these? and if so how easy difficult was it?
cheers
Post #225075 25th Nov 2013 11:22am
is there not a switch on the front console that switch's the heat to the rear on and off?..would it be that maybe/ ... - .- -.
Post #225079 25th Nov 2013 11:33am
andyleeds
its the speed of the fan rather that the heat setting..... it should be variable controlled by a dial.... but it either full on or off, hence i think that its the resistor...
andy
Post #225081 25th Nov 2013 11:42am
understood.. Thumbs Up ... - .- -.
Post #225085 25th Nov 2013 11:49am
andyleeds
question is where does it go? Wink
Post #225086 25th Nov 2013 11:53am
anything in the WM? ... - .- -.
Post #225087 25th Nov 2013 11:57am
Given the fan is controlled by a switch at the rear of the consol and the fan is located at the rear of the consol I would hazard a guess that the resistor is located somewhere near to the switch / fan.
I would pull off the access panel below the fan switch / heat control switch and have a look.
Post #225095 25th Nov 2013 12:53pm
BILLTU
United Kingdom 2016 Range Rover Vogue TDV6 Indus Silver
This is wha the Desription and Operation section of the WM says
Rear Blower (High Line System Only)
The blower is installed between the front seats, in the rear face air duct, and consists of an open hub, centrifugal fan
powered by an electric motor. Operation of the electric motor is controlled by a thumbwheel on the rear passenger
face vent via the ATC ECU and an output stage (voltage amplifier) installed in the outlet of the fan.
The thumbwheel operates a variable potentiometer which outputs between 1.25 V (blower off) and 5 V (maximum
blower speed) to the ATC ECU. The ATC ECU then outputs a proportional control voltage between 0 and 5 V to the
output stage, which regulates a battery power feed from the rear blower relay to the blower to produce the related
blower speed.
The rear blower relay is installed in the rear fusebox and energised while the ignition is on. 2016 3.0 Vogue
2006 4.4 V8 Vogue SE-sold
Honda CBR 1000cc Fireblade
Bultaco 350 Sherpa
Post #225096 25th Nov 2013 12:54pm
andyleeds
cool, will have a look and see what i can see....
andy
Post #225146 25th Nov 2013 4:45pm
Lous2311
United States
Andy did you find where the rear blower output stage located? I need to change mine and any tips would be great.
Post #304235 11th Jan 2015 7:16pm
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
My rear blower blows hot or warm air unless the blower is turned up to full then it will blow hot or cold depending on temp setting. Is this likely to be the resistor? There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #304473 12th Jan 2015 5:14pm
Lous2311
United States
Rear blower output stage or FSR location
Rear blower output stage or FSR location. I had to unbolt the center console and lift the back up to get to it. It's screwed into the bottom right of the blower in the center console.[[img]img]
Post #304906 14th Jan 2015 3:16am
pics added..
thanks for the info louis Thumbs Up ... - .- -.
Post #304921 14th Jan 2015 8:47am
