Home > Technical (L322) > Knock Knock
ksmith100
Scotland 2005 Range Rover Vogue 4.4 V8 Java Black
Knock Knock
No its not a joke, although I wish it was!
My L322 Range Rover has had a knock/clunk on the passenger side for about 3 months. It is most evident when turning right at slow speeds, like pulling into a car par or parking space, or a slow right hand turn on a road. Sometimes it can be heard at speed over a very rough road, and it is evident when off roading at slow speeds. It doesn't appear to have worsened over that time, no louder and no more frequent.
Everything has been checked, by two separate garages (both with lots of LR experience). There are no worn bushes or ball joints on the suspension, nothing shows any sign of wear even when testing the car off its wheels with a big pry bar, nothing moves the way that it shouldn't, all bolts etc. are tight, the road wheel nuts are tight, its not a clicking sound so its not likely to be a CV joint, it's a clunk, and only when turning right.
I have been through the similar posts on here and while I can find post containing the same symptoms none of the offending parts mentioned would appear to be worn on my car.
Apart from the suspension strut, is there anything else that can cause such a noise which may not be showing obvious signs of wear?
TIA You are either at Le Mans or waiting for Le Mans
RSW MKIII V2 All Comms in Central Scotland
Post #225198 25th Nov 2013 9:07pm
Sounds like the arb drop link is worn out can get overlooked by some garages easy way to tell is to go out to the car and give it a shake and see if you can feel excessive movement....
Did mine, super easy and cheap, driver side actually rattled when i jiggled it There is nothing that can't be fixed with a hammer😜😜
Post #225199 25th Nov 2013 9:18pm
b20wht
I also have a similar noise. Its been there since I got the rr and not got any worse. If I had to put money on it I would also say arb link but I have pulled and pushed on mine a few times and cant get any noise or play from it! It had a new strut fitted the day before I picked it up so don't think its that either, its so bloody annoying that I cant find it Evil or Very Mad
One thing to check is that your brake pads are tight (not to tight though) in the carrier and not rattling around as they can make a fairly loud clunk noise if they are loose fit.
If you fix it please let me no what you find.
Post #225232 25th Nov 2013 10:46pm
Have the so called "experienced tech's" jacked the car up under the bottom wishbone (to raise the wheel off the ground in its ride position not extended) and tried the bushes, ball joints and ARB links then?
As you may not find the route of the knocking if the suspension is fully extended instead of in it's "usual ride height"
Post #225236 25th Nov 2013 10:53pm
Need to be on dead flat ground or there will be a torsional force on the arb, and the drop links will be in either compression or tension... There is nothing that can't be fixed with a hammer😜😜
Post #225237 25th Nov 2013 10:54pm
paneldamage
Try tightening the pinch bolt on the inboard end of the bottom track control arm, I think it can make this noise, it's difficult to find by just prying the bush/ arm, it will only move a fraction under the full weight of the corner when a direction change is made, the tiny bit of movement is amplified through the subframe
Post #225240 25th Nov 2013 11:00pm
ksmith100
Thanks for the replies.
I should really have mentioned the drop link and lower arm and upper arm have been changed on that side, apologies for missing that out.
@b20wht
If I ever track it down I will let you know! Does yours sound like a shock absorber rapidly moving up and down?
@Cam-Tech-Craig
The people I refer to are Land Rover trained technicians, including a master technician. One garage is an ex-land rover/rover dealership. They gave up the sales side when the father died and the sons took over the business, about 30 years ago. They also maintain the local mountain rescue Land Rovers. Bushes etc. have been checked in normal ride height and with the wheels off the ground.
@paneldamage
I know the noise you mean, I had that not long after I collected the car. The master tech at the garage identified that noise simply by driving out of the forecourt!
So anyone have any other ideas? You are either at Le Mans or waiting for Le Mans
Post #225293 26th Nov 2013 10:40am
L322RR
Germany 2004 Range Rover HSE Td6 Zambezi Silver
Had exactly the same stuff, came from the steering ball joint. Was making me crazy. Excessive play, and after a year, brake disc warped. Changed (+ both discs), noise gone.
Post #225348 26th Nov 2013 3:49pm
ksmith100
That's interesting, would you have a part number of diagram of that part to confirm? I havent had any issues with brake discs or brakes in general.
Post #225350 26th Nov 2013 3:54pm
L322RR
No I don’t, had it done by a forum member. But what he did is he jacked up the car, and pivoted the wheels, klonk was then very noticeable, and you could see the play. Discs problems happened much latter.
Post #225352 26th Nov 2013 4:04pm
ksmith100
Unnecessary quote removed
That's the difference, there is no noise when you test any of the joints or pivot the wheels Sad You are either at Le Mans or waiting for Le Mans
Post #225353 26th Nov 2013 4:10pm
steve9bug
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
With the car on the ground loosen the inner bolt on the lower arm and then re tighten it. If it was tightened on the jack the bush will we under the wrong load it gives a small knock I found that out when I did mine
Post #225357 26th Nov 2013 4:28pm
ksmith100
I will ask the garage to do this, its not weather outside for lying on the ground! However they normally do all that with the car still on a 4 post ramp on its wheels, but still worth a try You are either at Le Mans or waiting for Le Mans
Post #225358 26th Nov 2013 4:31pm
Monty1
England 2005 Range Rover Supercharged 4.2 SC V8 Rimini Red
i had the same problem it was the track rod end
Post #225477 27th Nov 2013 9:25am
ksmith100
No play or movement in the track rod ends You are either at Le Mans or waiting for Le Mans
Post #225480 27th Nov 2013 9:37am
