Home > In Car Electronics (L322) > Bulb Out.
markdotreed
Bulb Out.
OK... Arrived at work this morning to be told I've a headlight out.... Not sure how long it's been like it but need it fixed asap. upon inspection it looks like the normal D3S Xenon bulb.
Couple of questions.... firstly can someone please confirm I only need to replace the bulb, secondly where should I buy these from and third should I replace both whilst I'm there with brighter (6000??)
a couple of pics. (2010 AB)
Main stealer is just around the corner from my work (Harwoods woods in Basingstoke) Should I just bite the bullet and buy from there?? Regards
Mark
2009 D4; 1993 Classic 3.9 VSE
Post #225276 26th Nov 2013 9:26am
Mark, A, change the two bulbs side to side first to make sure the fault is infact the bulb (affected bulb should not work in either headlamp) as these are more prone to headlamp ECU issues Thumbs Up
B, The bulbs from a main dealer are hundreds of pounds! Shocked As they very very rarely go wrong...
If you want to stay OE we have loads of these new & used in stock Thumbs Up If its your ECU we probably have one too Thumbs Up
Let me know if of interest sir Bow down
Post #225279 26th Nov 2013 9:51am
markdotreed
The Reply I was hoping for. Thanks Craig, will carry out diagnostic tonight. Regards
Mark
Post #225282 26th Nov 2013 9:56am
No worries Mark Thumbs Up
Post #225284 26th Nov 2013 10:03am
markdotreed
Bulb is definitely the culprit. Craig, can you give me some options please.. Currently it's a Philips M811.. Are there brighter / bluer options for instance. Regards
Mark
Post #225372 26th Nov 2013 7:39pm
Mark, the current bulb in your car runs at 4.6k temp range if you want to go slightly more blue/modern then i would suggest a pair of 6k phillips bulbs...
Craig Thumbs Up
Post #225502 27th Nov 2013 11:37am
markdotreed
Have you got a couple of 6K bulbs in stock Craig, what't the damage? Regards
Mark
Post #225507 27th Nov 2013 11:55am
PM sent Mark Thumbs Up
Post #225511 27th Nov 2013 12:23pm
Mark, did you receive my PM? as i have heard nothing back from you sir...
Post #225719 28th Nov 2013 12:20pm
markdotreed
Sorry, was busy yesterday. I've replied. Regards
Mark
Post #225723 28th Nov 2013 12:33pm
wealy
As a matter of interest - if a bulb (hid, sidelight or brake light) do we get a warning on the dash?
Post #226444 1st Dec 2013 11:25pm
yes.. ... - .- -.
Post #226468 2nd Dec 2013 9:05am
markdotreed
Been away for a few days..........
I didn't get a warning light when my bulb went but unfortunately do now. It seems the 'cheaper' bulbs don't agree with the cars electrical system and although produce a good light I will be ordering some of Craigs in the next few days as the warning annoys me, Regards
Mark
Post #226511 2nd Dec 2013 2:00pm
