Home > In Car Electronics (L322) > digital tv installation
sikegan
Ireland 2002 Range Rover Vogue 4.4 V8 Bonatti Grey
Hi just trying to find if anyone has installed the twin aerial digital tuner from Parkmyauto? the basic connections are straight forward but what I would like to know is how to wire up the power supply rather than having to search through the RAVE schematics. thanks for any assistance in advance.
Post #225602 27th Nov 2013 6:50pm
You will have to break into the power lines going to the other AV kit - purple and brown IIRC, or run cable across to the rear fuesbox, all depends if you want pre-ignition on power (always powered) or post-ignition on power.
Browse the in car electronics threads, there will be some pictures somewhere .
Post #225626 27th Nov 2013 8:43pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Yes I've installed the kit from Parkmyauto. From what I remember it was relatively easy to install and the instructions where reasonably clear. I can't quite remember what the procedure was with the power - I 'think' the instructions tell you which cable it was - but I found Russell extremely helpful - if you email/call him before you buy he will tell you how it all wires up.
If I get time in the daylight tomorrow I will check the install and remind myself how it was wired up and add the details here. Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #225802 28th Nov 2013 10:01pm
sikegan
have emailed Russell but would appreciate any help you can give
Post #225822 28th Nov 2013 11:54pm
