Home > Technical (L322) > Black smoke and ENGINE SYSTEM FAILURE messages
drivesafe
Australia 2007 Range Rover Vogue TDV8 Stornoway Grey
Hi again folks, and I have now got another unknown problem.
About a week back, my wife noticed a large amount of black smoke when I did a normal acceleration from an intersection.
I noticed this continued every time I did a normal from stop or slow speed acceleration.
About 4 days ago, I got an “ENGINE SYSTEM FAILURE” message and lost power.
I coasted to the side of the road, turn the ignition of and then on again and all was well.
I have just completed an oil, oil filter, fuel filter and air filter replacement but I am getting more and more “ENGINE SYSTEM FAILURE” messages and power loses.
Today I did a round trip trip of 20 Kms and it failed once going out ( 10 kms ) and 3 times on the return trip.
I did a search and found plenty on black smoke but not with the power failures so any Ideas and/or suggestions would be appreciated. 2007 TDV8 Lux
Post #225867 29th Nov 2013 10:02am
i'm not familiar with the tdv8 engine but the DPF springs to mind, try a forum search and see if the symptoms are the same.. ... - .- -.
Post #225871 29th Nov 2013 10:05am
Plug into diagnostics for the codes my friend...Kind of p Censored g into the wind guessing Thumbs Up
Post #225872 29th Nov 2013 10:05am
Too early for a DPF Stan... 2010> ish for DPF Thumbs Up
Post #225873 29th Nov 2013 10:06am
Embarassed i'm all wet now.. Mr. Green ... - .- -.
Post #225874 29th Nov 2013 10:07am
Question Question Question Rolling Eyes
Post #225878 29th Nov 2013 10:11am
Post #225879 29th Nov 2013 10:13am
Ahh, it's early love Thumbs Up
Post #225884 29th Nov 2013 10:18am
drivesafe
Thanks folks, kind of figured that would be the case, but just asked in case it was something as simple as the silencer solution on the air suspension.
I suppose I should be grateful, this pussbox actually operated properly for just on a week. First time in 6 years. 2007 TDV8 Lux
Post #225943 29th Nov 2013 12:32pm
cass
It's worth checking the air hoses from the intercooler for splits - there's also 2 x 2 inch diameter hoses that are hidden under the engine cover, 1 on the rocker cover of each bank of cylinders. They would cause the same symptoms if they are split.
Post #225973 29th Nov 2013 5:09pm
drivesafe
BTW, again would an OBD tool help.
I would have one now but I have had no response from a certain company, even though I have e-mailed them twice to see if there is a local supplier.
There is a Yankee made one, but not sure how it compares. 2007 TDV8 Lux
Post #225974 29th Nov 2013 5:10pm
drivesafe
Thanks cass, I will check them in the morning. 2007 TDV8 Lux
Post #225975 29th Nov 2013 5:12pm
Martin
Site Admin
Could well be the two intercooler pipes - just like the D3 one they split or delaminate and cause this.
Post #225976 29th Nov 2013 5:13pm
Martin
Site Admin
See http://www.fullfatrr.com/forum/post133083.html#133083
Post #225978 29th Nov 2013 5:14pm
drivesafe
Martin wrote:
Hi all,
Dad's 08 TDV8 has got a bit of a strange issue.
Under light pedal application - pulling out of junctions, etc - it will intermittently flag up "Engine System Fault" on the dash, special programs unavailable etc and go into limp home mode. Key off and restart and it is either OK, or it does it again. Putting it into a TR mode other than Normal seems to stop it doing it.
Now, the odd thing is - it has only done it when above about 1300m altitude, below that is absolutely will not repeat it.
Anyone had similar?
Thanks Martin, this is almost exactly what is happening to mine.
In my case, it is fine on flat running but even the slightest hill and after a few seconds, lose of power and the message.
If i accelerate up the same hill, it does not fail?
Again, I will check all the pipes in the morning.
Thanks again all. 2007 TDV8 Lux
Post #225982 29th Nov 2013 5:31pm
