![]() | Home > Technical (L322) > Open door error - HELP! |
paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222 ![]() ![]() |
Strange, cos if the door lock sensor is not detecting the door is fully closed, it would show by the courtesy lights being on, I would start with the multiplugs on the drivers door outstation, have a really close look at the connectors and don't assume they are making a good connection - I had this on mine and it was one of the pins. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35827 ![]() ![]() |
maybe a phone call to the repairers and ask how they actually did the job and that might give you a clue where to look... ... - .- -.
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
Stan - very sensible suggestion! I'm already on that.
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
Would a problem with the bonnet sensor cause an open door warning? 56 TDV8 Vogue SE
Hmm. It can't hurt to try. Slammed all the doors, but I didn't think to check the bonnet. It's easy to check. Thanks! |
did you find a solution to this? |
Sort of. The next day the error was gone. It hasn't reappeared. I don't know why. As long as it doesn't come back, I'm happy. |
nice and simple repair then.. |
Well, it's a repair that matches my skill level.
The car has several micro switches in the door latch... Separate micro switches for the CL and for the Alarm... If it ever comes back, simply unplug and plug in all the plugs to the latch, get a screwdriver and latch the door (so it thinks it's closed) then you can check it all works |
Thanks CTCraig. Much appreciated. I've noted that in case it reappears! |
