Home > Technical (L322) > Heated screen problem, how do I check it?
b20wht
My drivers side heated screen is not working on my 2003 td6. I have read various posts and some seem to say that if 1 entire side of the screen doesn't work its unlikely to be the screen at fault and others say it is the screen!! The passenger side works ok so its not the fuse. I now need to test if I have a feed at the connection to the screen (drivers side) how do I do this? I tried to remove the airbag logo on the A pillar but it wont budge!? Also do I need to disconnect the battery so as not to set the air bag off then reconnect when I test the feed?
Post #225819 28th Nov 2013 11:29pm
May be easier to remove the top dash panel, then you can get at the wires to test ? .
Post #225827 29th Nov 2013 1:26am
b20wht
Ok I will give that ago thanks
Post #225924 29th Nov 2013 11:40am
b20wht
Just had a look on youtube at the removal of the top dash panel and cant see the wires for the windscreen once its off! are you 100% sure that they can be got to by removing it?
Post #226007 29th Nov 2013 8:18pm
b20wht
Someone must know how to get to these connections? I have searched all over and just cant find a guide or even a location (other than the bottom of the screen somewhere) Are they under the bonnet or under the dash?
Post #226193 30th Nov 2013 8:44pm
RR2008HSE
I had an issue with a windscreen replacement where either, it was defective, or the connectors were damaged during installation. (Solution was a new windscreen.)
When the mechanics were talking about it, they gestured towards the A pillars, so I assumed that's where the wires were. They didn't remove the dash fitting the windscreen.
I know it's not a precise answer, but it's all I know.
Post #226209 30th Nov 2013 9:31pm
paneldamage
Pretty sure they are under the scuttle panel, take the plastic push-in clips out, ease it away from the glass either side and have a look....if correct, you will have to take the A pillar covers off etc to remove the scuttle.
Post #226290 1st Dec 2013 12:40am
b20wht
are you talking about the outer scuttle and A panels? or the inside ones?
Post #226296 1st Dec 2013 1:49am
paneldamage
Sorry, missed your reply, I mean the outer A pillar covers, they wrap over the plastic scuttle finisher, I seem to recall the connections are in front of the passenger, if you look in the wiki there is a copy of the WSM and this will give you a definitive description....
Post #226438 1st Dec 2013 10:36pm
b20wht
Thanks for the reply, I have had a look through the wsm and cant really find much on the heated screen at all. But I will get the scuttle off and have a look. Thumbs Up
Post #226445 1st Dec 2013 11:29pm
