|  | Home > Technical (L322) > Wind Noise Drivers Side 50mph + |
| goldsax Member Since: 16 Jul 2012 Location: leicestershire Posts: 196      | had a similar issue in october .
|  2nd Dec 2013 10:11pm |
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3285      | Can also be the rubber strip in the rain channel. Mine came away at the front and was like a ski tip at speed so caused a drone noise. Fixed it down and no more noise!   | ||
|  2nd Dec 2013 11:12pm |
| carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717      | @ goldsax, will give the pillar trim a good press to see if its that.
|  3rd Dec 2013 1:07pm |
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3285      | Sorry wasn't clear! Can't take pictures as it was my prevIous rr and my present one has roof rails so it can't be seen.
|  3rd Dec 2013 1:13pm |
| pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218      |
 Where about on the A pillar is the noise coming from/ does is sound like a window is partially open?
|  3rd Dec 2013 3:07pm |
| carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717      | It sounds like it comes from the front corner, there's no draft between door and A pillar from inside the car so perhaps it a whistle from air getting under the A pillar trim and not being able to go anywhere?
|  3rd Dec 2013 10:01pm |
| pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218      | There was no draft with ours. | ||
|  4th Dec 2013 8:47pm |
| Posting Rules
