Home > Technical (L322) > Groan.... its starting to do my head in .(
Needle
2003 Range Rover SE Td6 Java Black
Ok had a quick look on here but id be here for ever trying to find the solution Sad( , got a 2003 td6 full fat , problem was it felt like the HDC was kicking in and applying the brakes ( aggressively) but only when pulling away , would do it for a few days then disappear for weeks then come back , nothing coming up on the ID tool ,,changed all the wheel sensors , checked the connections on the abs modulator but nothing there,HDC /air sus / Abs lights coming up,,,HELP .(
Post #226575 2nd Dec 2013 8:35pm
Do the lights go out when you turn the steering wheel full lock to full lock but then come back on again later? Previously..
Post #226582 2nd Dec 2013 8:54pm
Needle
nope they stay on
Post #226583 2nd Dec 2013 9:04pm
paul271
Scotland 2002 Range Rover Vogue Td6 Epsom Green
Take it up to Greenbank 4x4 mate. I use them for anything I can't fix and they're top notch.
Post #226591 2nd Dec 2013 9:34pm
mjdronfield
I'd guess its a reluctor ring on one of the driveshafts that's not sending a signal to one of the wheel speed sensors. Car thinks the other 3 wheels are spinning so activates abs. It then realises the readings are not right, so disables abs, dsc, etc
I had the issue on my rear passenger wheel, which is also used for the speedo reading.
I posted a thread on it around the middle of September.
Worth a check........ 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #226596 2nd Dec 2013 10:16pm
Dolphinboy
Look for gunge on the connectors in the ABS module. This is the first item on the canbus loop and when it throws a fault it also stops the info flow and triggers the HDC and other sensors. I had this once with all the lights on imaginable and cleaned a small spec of greeny corrosion off one connector in the ABS module and all good (see my gallery for pics)
Post #226597 2nd Dec 2013 10:19pm
