Home > Technical (L322) > Timed Climate V8 SC
suffsc
England 2009 Range Rover Supercharged 5.0 SC V8 Santorini Black
Timed Climate V8 SC
I have factory fitted timed climate on my ’09 V8 SC but it does not seem to do to work as I expected too.
The blower comes on when the car is unlocked but only for a few seconds so setting the timed climate via the screen or remote does do something but not a lot.
Does anybody have any experiences with timed climate on a V8 SC.
Many Thanks
Post #226570 2nd Dec 2013 8:01pm
Dolphinboy
Are you talking about the heating or cooling aspect? Most Petrol RRs dont have an FBH unless spec'd in the build. However it is possible to cool the car via the aircon I believe (may be wrong.. am sure someone will correct me.)
Post #226600 2nd Dec 2013 10:26pm
Some did have fbh fitted though i think it was an option rather than standard fit. Tricky to visually
Check as its hidden under the wheel arch...... There is nothing that can't be fixed with a hammer๐Ÿ˜œ๐Ÿ˜œ
Post #226603 2nd Dec 2013 10:33pm
E4 GUY
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
I have only used mine via remote, on frosty mornings to get worst off the windscreen.
Not done it yet this winter, but I don't remember if it is still blowing once I've unlocked the car.
You can hear it if you stand next to front near side arch
Been a little nervous to set via timer, or for much longer than 20 mins. My battery isn't great , even without FBH draining it Laughing Alcohol and eBay is never a good mix
2006 4.2 Supercharged, Java Black
Post #226611 2nd Dec 2013 11:10pm
Open the car up and turn the nav screen on but don't put you key in , go to timed climate in the set-up screen and turn the FBH on to manual , it should now start to run so leave it for ten minutes and see how warm the cabin gets .
If it turns itself off after a minute or so then Im afraid you have a problem that needs tracing . 2008 MY Supercharged
Post #226630 3rd Dec 2013 1:34am
