![]() | Home > Technical (L322) > PDC Parking Sensors fault |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
If its the rear and your getting no joy from either of the four sensors then the plug for the rear loom is located under the bumper skin underneith the drivers side rear lamp, so i would start there and make sure the plug is connected correctly and the connections are clean |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1527 ![]() ![]() |
There could also be a short where the harness crosses under the plastic and over the metal bumper (DAMHIKT)
webber Member Since: 26 Nov 2013 Location: Stockport Posts: 29 ![]() ![]() ![]() |
Thanks for the advice |
It's easier to take the bumpers off, then you can totally rule it out.
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 ![]() ![]() ![]() |
If none of he sensors are ticking (front or rear) the the fault is most likely with the rear sensors as the contol module will deactivate both. Issues with the front will only deactivate the front.
TugRR Member Since: 11 Jan 2011 Location: Bakewell Posts: 1200 ![]() ![]() |
Just a quick add on to Steve's above - rear bumper is easy, unless first you have to remove the mud flaps. A grinder may be required. If your car has them, just give yourself a bit of extra time -
Great info, thank you very much for that.
Ok bit of an update... I took the bumper off and decided to replace the rear wiring loom to the sensors as I was convinced there was a broken wire in there somewhere and the loom was only £40 so it seemed worthwhile.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3925 ![]() ![]() ![]() |
I couldn't hear mine ticking either, I thought I was going deaf so I went to the Doctor who all covered his bases and diagnosed "Sensory Impairment" boom boom |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
if the sensors and the wiring are ok then the next step is to replace the pdc control module... ... - .- -.
Despite my poor joke, mine have only worked immediately after a reset for a few seconds in the 3 years I have had the car. The IIDTool suggests that both the front offside and the rear offside sensors have a fault, is that likely to be an accurate diagnosis (is each sensor individually checked) or is that just generic for any of the sensors being suspect, and as I said no clicking as by the time I get round to either the front or rear as the system seems to have shut down
jarv Member Since: 12 Jun 2013 Location: London Posts: 30 ![]() ![]() |
Any update on this Adam as I have a similar issue with my PDC?
gav Member Since: 03 Jan 2014 Location: Hertfordshire Posts: 37 ![]() ![]() ![]() |
I have a funny issue with my PDC on my 53 4.4 vogue
Water ogress into the sensors probably... 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior |
