Home > Maintenance & Mods (L322) > Rear washer mod
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Rear washer mod
Ok looks like I got to do the mod on the rear wiper washer......water leaking on to parcel shelf!
I took off the trim and low and behold brown water on the inside of trim and plastic outlet on wiper motor... Big Cry
Now my question is has anyone done this mod AND its worked well so stop this reoccurring?
http://www.fullfatrr.com/forum/topic9924.html If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #225395 26th Nov 2013 9:47pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Bought the washer, will be going for it shortly...
Post #225431 26th Nov 2013 11:08pm
supershuttle
I bought the washer but had to fit both the old and new to get it to seal. Also remember to put the bolts back in the spoiler - that still hurts Very Happy Geoff
Post #225605 27th Nov 2013 7:03pm
Welshdragon
Shocked
ok note to self, if I have any bits left over, something not quite right!
I guess its all still good then?
I just ordered the seal so this weekend its butcher time to the motor Mr. Green If it dont work.......burn it!
Post #225609 27th Nov 2013 7:18pm
Welshdragon
So, having a go at the wiper mod this afternoon, all was good with the seal and putting the wiper motor back on the tail gate, check it works and a nice squirt of water from the jet, thought I'd try it once more before putting the spoiler back on and.......... Censored it Censored water on the boot floor Big Cry Big Cry
Ok so off it comes again and this time the seal is now turned round so the retaining spring is facing inside the plastic housing and some silicon sealant to assist sealing to the outer casting..............I just need to test it in the morning to see if all is well OR not! Fingers crossed. If it dont work.......burn it!
Post #226259 30th Nov 2013 11:19pm
kruger2002
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Just checking
I've been looking at this tonight and wondering if it's the same problem on mine.
There's nothing coming out of the rear washer so I took the bits behind the plastic to try and fault find.
Took the supply to the plastic block (non return valve?) off and had water flow on demand from the stalk.
Had a play with the NRV, (looks like it comes apart but not sure how) put it back on and removed the flow from it to the washer, again got water when the washer stalk was activated. All ok so far so cleared the jets on the wiper itself and reconnected the pipes.
Result - brown water all over the boot and p Censored g out of the wiper mechanism.
Is this the same or do you have water coming out of the rear washer jets?? Currently - 55 FFRR S/C and loving it
Post #227452 7th Dec 2013 12:10am
Welshdragon
Rolling with laughter what a pita!
I had the water come out of that plastic to cast part, the seal inside was warn, so I did the seal mod with a bit of silicon to seal the plastic and casting for extra sealant sa the first time refitting it leaked.
My wiper jets where blocked on one jet but one blow with the compressor soon cleared that, now both jets work well Very Happy .
At the moment all seems ok, I just hope it don't leak again all over the load cover as that was a Censored to clean up afterwards. If it dont work.......burn it!
Post #227459 7th Dec 2013 12:31am
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Load cover .... do people actually leave these in???? Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #227465 7th Dec 2013 12:59am
jfb1977
England 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
This happened to me and in the end it was easier to buy a new rear washer motor and assembly to sort the bloody thing out. Censored Past (too many to list, but a few favs)...
2007 Porsche 997 C2S Coupe
2007 FFRR 4.2 S/C
2012 Jag XKR 5.0 S/C
2014 Merc SL500 AMG 4.7 V8 BiTurbo (remapped to 560BHP)
2011 FFRR 4.4 TDV8 Vogue SE - Overfinch Conversion
2012 Porsche Cayenne Turbo
2018 AMG C63S Estate
2015 Mercedes GLE63S
2017 Maserati Levante Diesel
2017 Audi A6 Avant 3.0 Black Edition
Post #227467 7th Dec 2013 1:07am
jfb1977
Dan @ Duckworths was the cheapest for the new bits by quite a long way BTW. Past (too many to list, but a few favs)...
2007 FFRR 4.2 S/C
Post #227468 7th Dec 2013 1:07am
Welshdragon
that's good to know for the next time, if it leaks again I just might get a new one...save all that hassle with taking motor off twice!
The washer was about £3 and a bit of time, a new motor £120? ish of the bay of e.....no comparison really if the fix works. If it dont work.......burn it!
Post #227511 7th Dec 2013 1:09pm
Well it worked for me, so hopefully you wont have to splash out on a new motor Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #227514 7th Dec 2013 1:18pm
Welshdragon
Thumbs Up Thumbs Up Thumbs Up If it dont work.......burn it!
Post #227575 7th Dec 2013 8:31pm
GJOB
2005 Range Rover Vogue SE Td6 Java Black
Are there any other recommended places to buy the right washer as the link leads to eBay but the seller seems to have run out?
Cheers
GJOB
Post #229653 16th Dec 2013 10:36pm
Welshdragon
I got mine from this chap Thumbs Up
http://www.ebay.co.uk/itm/10x16x4mm-Metric...796wt_1162 If it dont work.......burn it!
Post #229681 16th Dec 2013 11:42pm
