![]() | Home > Maintenance & Mods (L322) > trans-failsafe-prog. |
jak480 Member Since: 06 Dec 2013 Location: Degernes Posts: 44 ![]() ![]() ![]() |
I had it once and the motor to engage the low gears needed to be changed. |
SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792 ![]() ![]() ![]() |
^^^^ Yep, could very well be the transfer shift motor. Does it go into low and back to high range ok?
henry nelson Member Since: 09 Oct 2011 Location: carlisle Posts: 43 ![]() ![]() ![]() |
Hi both sorry it took so long to reply, it turns out all it needed was all the error messages deleted from the computors, there was at 50 of them for the suspension a loan so managed to find an independent where I was staying near Carlisle and he cleared every thing that was wrong, runs fine now, cheers. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Have your battery looked at then sir... |
Cheers Craig, it had a new battery last year when gear box was re-built but I will get it checked. The garage that cleared the faults said that they had not been cleared right, so I hope nothing comes back. cheers. |
