Home > Technical (L322) > Supercharged Range rover Gearbox
Av_dave
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Hi, I purchased a FF supercharged range rover recently, I'm guessing this had the 6 speed box in it? My question is wether to have a oil and filter change on done on the auto box? One of my previous RR a 04 td6 had to have a new gearbox at 80,000 miles.
Thanks The difference between theory and reality is that in theory it will work.
Post #227885 9th Dec 2013 10:40pm
Yes will be the 6 speed.
It is the same gearbox as on the tdv8 pretty much, so same principals apply, recommended change is at 100k, but if the gearbox has been used heavily or for towing then 60k is preferable.
So yes it is advisable to swap the fluid, personally wouldnt go the megaflush route but would buy the parts and fluids from dan and get your local md to do it. Mine charged me an hours labour.
The valve block in the 6hp26 is much more robust than the one in the td6. It is very important to get the correct fluid, either zf longlife 6 or the gen lr fluid. There is nothing that can't be fixed with a hammer😜😜
Post #227943 10th Dec 2013 12:45am
Av_dave
That's great info thankyou, silly question who is Dan? To get the mega flush stuff from?
Thanks
Dave The difference between theory and reality is that in theory it will work.
Post #227975 10th Dec 2013 6:48am
E4 GUY
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Dan at Duckworths, site sponsor.
Thumbs Up Alcohol and eBay is never a good mix
2006 4.2 Supercharged, Java Black
Post #227981 10th Dec 2013 9:02am
Av_dave
Spoke to my local independent land rover garage today and got it booked it for a flush and oil and filter. It may have been done before but for small outlay I think it's worth the piece of mind.
Thanks for the input The difference between theory and reality is that in theory it will work.
Post #228404 11th Dec 2013 7:29pm
