Home > Technical (L322) > Sticky drivers door handle
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
For want of a better description, my drivers door handle is a little sticky. It seems to be catching slightly about half way through the travel when opening the door.
Presumably there is a cable from the handle to the mechanism - does anyone know if its possible to oil it without taking too much of the door apart?
I've sprayed some WD40 down the sides of the handle, on the mechanism and on the visible internals when removing the lower rubber grommet.
Thanks all in advance Thumbs Up 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #227761 9th Dec 2013 9:49am
you might temporally solve the problem with lubrication but i fear its the cable breaking down..i'd replace it asap before it breaks...there's one cable from the outside handle to the latch and another from the inside to the latch... ... - .- -.
Post #227774 9th Dec 2013 11:29am
Oe_tuning
Singapore 2004 Range Rover Vogue 4.4 V8 Epsom Green
Hi Graemec,
Are you referring to the inside or outside handle?
I have a problem with my outside handle where I need to pull it really hard to open the door, about twice the effort than other door handles. Am wondering whether your solution can be applied to my problem Smile
Post #228052 10th Dec 2013 4:38pm
GraemeC
My problem is with the outside handle, the internal handle is fine
Seems to point to the cable between the outside handle and the latch mechanism breaking down as per Stan's post
I will have a look through the workshop manual to see what's involved with taking the door card off to get to the handle/mechanism cable, with a view to replacing it
You just know its one of those things which will break on a cold, rainy night miles from anywhere, when you're late and with the wife and kids in tow..... Mr. Green 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #228065 10th Dec 2013 5:20pm
^ and the fuse blows on the central locking. Wink Smile
Post #228072 10th Dec 2013 6:03pm
GraemeC
LOL look on the bright side!! Thumbs Up 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #228122 10th Dec 2013 9:12pm
wats39
Scotland 2004 Range Rover SE Td6 Alaska White
Same happened to mine. Kept putting it off then pop! Censored couldnt get in the door. Used the remote to put the windows down and opened the door from the inside handle till i got it fixed. '04 td6 se
'63 land rover s2 200tdi
'04 mk indy kitcar bike engine
Post #228129 10th Dec 2013 9:23pm
