![]() | Home > General > MY11-MY12 |
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
Craig,
Your only example 2011 car has a black splitter & fogs and does not have body coloured door handles. here is YOUR link: http://www.ebay.co.uk/itm/Land-Rover-Range...9013115218 The cars in this advert you quoted above has the newer grille but has obviously been modified along with L405 Wheels. Not even sure if he bothered with fitting 2012 lights as they look a bit pale to me. Either way it been modified. You only other advert was an Overfinch conversion/upgrade. No evidence again. 2012
2011 (your example)
Last edited by Gazellio @ Prestige Cars on 11th Dec 2013 12:49am. Edited 2 times in total |
| DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027
With Gaz here ... I was a bit baffled by the examples as they don't support your case - unless you are getting confused and posting the wrong links |
2012MY picture from the JLR 2012MY Brochure
Another example from same 2012MY Brochure. Forgot to mention the colour coded half wing mirror and door handle covers:
A side note to anyone that is going to take a 2010+MY out to play in mud - those front 'splash guards' at the bottom of the bumpers are not attached very cleverly - so it might be worth removing them if you know you are going to go to bumper depth. Experience has shown me this! |
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
Your not listening... Both of the above pictures you have posted are of RR's with the SC AB Noble grills fitted... The 3 bar grill pictured was also fitted to the Westminster as standard too! But is not a standard fit 2012 grill simple Another 2012 car here with a standard 2012 (non noble plated) grill note it's a VSE not an SC AB or Westminster............ http://www.ebay.co.uk/itm/Land-Rover-Range...2c75cf01ac |
The 2012 Westminster & The SC have the new 3 Bar design not seen before 2012:
That's exactly what I said Gary... BUT not all 2011.5 or 2012 cars are SC's AB's or Westminsters are they!!! Your statement was all 2012 cars have the 3 bar grill and the silver bar & fog surrounds were not available before 2012... |
This document says that at 2012MY launch only Westminster, SC & AB where available....
Final post here as bored:
| Philip Member Since: 05 Jan 2010 Location: UK Posts: 2626
That's the price list from April 2012, when the Westminster replaced both Vogue and Vogue SE. Before that, 12MY Vogue and Vogue SE were available - plenty around on 61 plates. All supercharged cars have been Autobiography-spec in the UK since the 10MY facelift.
Where the pre Westminster Vogue/Vogue SE 2012MY though or 2011.5 MY on 2012 plates. Pre full 2012 MY Launch?
Nice touch that Gary... Only listing the price list for the 2012my AB SC & WM... Ahh the three models that come standard with the 3 bar grille... |
12MY - black grille surrounds, painted vents and door handles, black light bases. Just look on Auto Trader. Westminster is just the run-out model. |
