![]() | Home > Technical (L322) > FBH |
| Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1673
FBH kicks in under 6 deg C? |
| CSK Member Since: 15 Oct 2010 Location: St Tropez Posts: 750
God Martin that was quick! The owner's manual says heat below 15°C but maybe it kicks in at a lower temperature. |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35880
http://www.fullfatrr.com/wiki/FBH |
| DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027
I thought it was 8 degrees. Land Rover Addict
Taken from the 2010 owner's manual on TOPIX:
Ah ... sorry I was rather stupidly assuming you meant as an aux heater (i.e. on automatically to help warm up the cabin - as in a TDV8). You've got an SC so it should in theory work along the lines you've quoted, however I think it's hit and miss as in the summer if I hit the remote on mine it heats the cabin even if it is (very rare I know) over 20 degrees C ..... your's seems to be switched the other way, as if it only had timed ventilation and no aux heater! (the BMW era 4.4' petrols have this option....) Land Rover Addict
Normally if you've got the option of "Timed Climate Control" which mine has, it shouldn't make any difference if it's petrol or diesel, it works in the same way (only those who have the option, not the standard item).
| XXXAngelXXX Member Since: 25 Mar 2007 Location: Stuttgart Posts: 4995
i had the FBH option my former 4.2l SC |
Do you remember below which temperature the heater set in instead of the ventilation? |
| fairwx Member Since: 10 Nov 2011 Location: bristol Posts: 124
This may be relevant if the have replaced the FBH.
Thanks saw that but it doesn't give more info that what is already explained in the owner's manual.
honestly i never used it in 3.5 years of ownership 2024 RR Velar 2021 AM new Vantage |
Tried it early morning at 9°C and still blowing only cold air, seems a new unit didn't solve the problem! |
i'd wait for colder temperatures as the wiki says less than 5 degrees for the fbh to work.. ... - .- -.
| All times are GMT |
